Forum: Old versions
Topic: Virtual DJ + External Mixer Recording?
masburyHome userMember since 2009
I'm running virtual dj 4.3 on a macbook 2.4ghz and NuMark DJIO external sound card. I have an external mixer, no turntables and everything works fine except recording. I can't seem to figure out how to record from my mixer instead of from my "master" input.
I've tried selected the "Line In" option in the record menu but then the sound is blank when I play the finished recording. When I select the "master" input from the record menu, it records everything including my cues. The main reason I would like to record from my mixer is to mix without hearing the cues.
I've also tried going into the system preferences and changing my input sound to the DJIO sound card.
geposted Thu 15 Jan 09 @ 12:48 pm
spinnaJPRO InfinityMember since 2004
Hi masbury, it be better if u register ur serial in ur profile and update to V5.2.1 mac;)
U have to use the internal card in line in option;)
geposted Thu 15 Jan 09 @ 12:59 pm
I'm new to this forum, I didn't know I had to register :s.
There's a problem, I don't have that option under "Line-In", maybe vdj isn't compatible with DJIO?
geposted Thu 15 Jan 09 @ 1:03 pm
Ok. no problem..and welcome to the mac forum.
To get started you just go to "modify my profile" tab and register ur serial there. Then u can download the recent version. V4.3 is an old version n the first version for mac.
Djio is compatible with vdj so no worry;)
Regards;)
geposted Thu 15 Jan 09 @ 1:13 pm
geposted Sat 17 Jan 09 @ 9:05 pm
The DJiO doesn't have a line in...
geposted Tue 20 Jan 09 @ 3:42 pm
what do you mean? btw my friend has the same setup on a pc and the djio works
geposted Wed 21 Jan 09 @ 6:14 pm
The DJiO provides an audio interface to get from your program to your mixer, but not the other way around.
If you want to record using your external mixer's fader, you have to send the master out from your mixer back into your computer. The DJiO is a 1-way street.
I use another computer with a Lexicon Alpha to record from my external mixer.
J
geposted Wed 21 Jan 09 @ 8:49 pm
It be better to use the newer updated version than V4.3;)
Pls register in ur serial and upgrade to that. Thanks;)
geposted Thu 22 Jan 09 @ 5:18 pm
LukeLBSPRO InfinityMember since 2010
BUMP
I'm having the same issue but I'm use the DeeJay Trim.
When I switch to line on the back of the soundcard it doesn't give my timecode a signal. When I switch to line on my mixer I get static. Same thing when both are on.
UPDATE!
I got it working on line but still records my cues...
geposted Fri 04 Jun 10 @ 11:26 pm
LukeLBS wrote :
BUMP
UPDATE!
Okay I click the inline option in the record config I get a waiting to start message. Reset Factory settings didn't work I can record in master just fine.
geposted Sat 05 Jun 10 @ 3:33 am
Come on guys I payed money for this program and I can't even do what I want to do on it.
Someone has to help me out here.
geposted Sun 06 Jun 10 @ 11:55 am
Bump
geposted Thu 10 Jun 10 @ 2:31 pm
hi luke, sorry for late reply.
yes, with the current version me too can't record too. It could be a bug anyway i will check or try to get info on it.
in the meantime you can use audacity on the same system or you can channel it out to another system to record your mix.
best regards;)
geposted Mon 14 Jun 10 @ 7:28 am
heya i am new to this and am just wanting to record my tracks off virtual dj. i go to configure and select a spot but then it doesnt let me listen to it?? i have downloaded MAX as someone suggested that but it doesnt do anything to the file...
geposted Sat 14 May 11 @ 12:39 am
