Forum: Old versions
Topic: New Macbook and Hercules RMX = not working
Shay.caHome userMember since 2009
Hello, i have a bran new Apple Macbook aluminum 2ghz and 4gb ram and i just picked up a Hercules RMX...
I installed the Software off the CD, installed VDJ software
when i plug my RMX in, a lot of the blue lights flash crazy a bunch of times and it doesnt work..
ive d/l the drivers and stuff and still cant get it to work right..
can someone help me out step by step (ill remove everything and we can go over it all from the beginning) because i just cant seem to get it right tonight, ill try again tomorrow
you can get ahold of me over msn or YIM
msn: XXXXXXX
YIM: XXXXX
thank you for your help ! ill be on tomorrow
Moderate by spinna
Sorry no email or contact by no license user
geposted Fri 06 Feb 09 @ 10:00 pm
spinnaJPRO InfinityMember since 2004
Hi the best thing is to register with ur DJC version serial on ur profile. Then get the recent updates to V5.2.1 DJC
Regards;)
geposted Fri 06 Feb 09 @ 11:22 pm
geposted Sat 07 Feb 09 @ 2:58 am
How do you register it ?
geposted Sat 07 Feb 09 @ 8:21 am
Ok i figured out how to register it.... but i bought it used and the guy that had it before me registered it.... is there a way he can Un Register it ? so i can REgister it ?
geposted Sat 07 Feb 09 @ 8:24 am
cstollPRO InfinityMember since 2004
No once a license is registered then it can not be transferred. You will need to purchase a Pro license if you want the updates to the software.
geposted Sat 07 Feb 09 @ 11:33 am
