Pulse ... Thanks for the Quick Reply. I appreciate the responsiveness, If you say they will fix it I take your word.
Sincerely DJ JAMM
Sincerely DJ JAMM
geposted Tue 09 Jun 09 @ 6:19 pm
DJJAMM wrote :
PLEASE SOMONE OUT THERE( please help the development team, and explain exactly to them how the platter is supposed to operate.
Some obviously don't read and I if you think I am taking offense ... then I am ... obviously someone from Atomix themselves isn't a good enough word ...
If you can't wait ... I will gladly make 5.2.1 available for download if you had it before ... but I don't truly understand the day-to-day ...
You want to blame someone by name to make you feel better ... blame me .. I wrote the mapping for it and I am the one that did the testing on it .... Its has been reported and it will be fixed when it can ... and when its ready you will know ... I don't have a day or time ...
Cheers ........
geposted Tue 09 Jun 09 @ 6:47 pm
Hi. I've been following this as well, and thank you for all your efforts (especially you cstoll).
I'm playing around with virtual dj 6.0.1 with my cdj-400s... it's brutal. I've ripped through all the options, mappings, etc, and nothing is changing the "lag" with the platter. It must be programming wise. Even playing a song and just pressing down on the platter is delayed by at least 500ms.
Also, the CUE button, i've set that to cue_stop, and it's doing what I personally think it should be doing (play as long as it's held down), however, this too is lagged. Try this for testing:
1) cue up a beat on a song.
2) start tapping the cue button on beat to another song (is it lagging? No? see next step.)
3) start tapping the cue button double bpm (8 taps per one bar 4/4 time). It should be lagging on you.
And umm, I find it isn't just the cue button it lags on. It's also the hot cue buttons at the top (the 3 buttons for cues when not pressing "hold"). You can tap the hotcue buttons on beat, but you can't go fast than that.
.... and the play button is delayed by at least 200ms.
If you want me to, I can make a video for you. I can't really explain this any better.
Now a few questions:
1) How do I set effects to use while pressing HOLD and one of the 3 effect/cue/sample buttons?
2) How can I delete a hot cue without finding it in the waveform and right click?
3) How can I change the reverse button to do a forward reverse (tack continues in forward motion, but plays it backwards)? This would be great for blocking out swear words :)
4) What does "MEMORY" do? lol
I hope I can help in this investigation! :)
Thanks for all the help!
- DJ Stoyvo
- DJ Stoyvo
geposted Wed 10 Jun 09 @ 12:10 pm
No video necessary .. I have the controller ---
Check your Performance tab ... if Safe Mode or Overclock is checked then UNCHECK them.
- DJ Stoyvo
- DJ Stoyvo
#1 - are you asking 'How do you use the Menu feature?' which is assigned to the HOLD button.
#2 - well you would need to assign a button to delete_cue # - the problem is # -- something that can be thought about.
#3 - change the action to -> dump
#4 - toggles the Smart_Loop feature (lock to the right of the skin's loop section)
AS TO THE LAG ISSUE ... I know what the issue is and it's a programming change that needs to occur ... when its been done and available I will let you know ... Don't need any more 'investigating' or 'feedback' ... it is what it is for now ...
geposted Wed 10 Jun 09 @ 1:12 pm
Afrog is right about lag in cueing. When I have a song playing on one deck, I tap the cue button on the other, which is cued right on a beat, when I tap it to match the other song it lags slightly behind...Also it doesn't always "kick on" when pressed or it's late. Also I want to know how to get the cue button working like it did in V 5. While previewing a song using the cue button the song will continue to play if I hold the button longer than a couple of seconds. I don't want it to do that, if I want the song to continue playing I'll hit the "Play" button, not the "Cue" button. How can I fix this?
Samples aren't beat matching like in the previous versions and pressing the "Sync" button for beat matching works but doesn't align the songs every time like in the previous version. The samples will play twice the speed they should and even when I switch to another sample while the other one is playing the old one won't stop playing, meaning on the same deck both samples will play and I can't find a way to stop the old one. I had to restart the program.
Chris, you seem like you are getting a bit agitated, I’m not pushing you to get these issues fixed ASAP I know it takes time, I’m just letting you know there’s a problem. I understand you guys are working on a thousand other things besides ours, so I understand this and I am patient, ok? Relax, CHILL homie!!! It's all good.
Seriously though, we appreciate the efforts you guys are putting forth, really.
Thanks,
DJ RuDe
Thanks,
DJ RuDe
geposted Wed 10 Jun 09 @ 2:17 pm
Exactly. Chris, take your time, just not 2 years ;) We can wait lol
geposted Wed 10 Jun 09 @ 4:18 pm
Definitely won't be that long :)
geposted Wed 10 Jun 09 @ 7:34 pm
- DJ Stoyvo
- DJ Stoyvo
Unchecking them made no difference.
And...
1) how do I get the actual effect assigned to each button though?
Also, is it possible to have a two button map? So HOLD + Cue 1?
geposted Wed 10 Jun 09 @ 8:58 pm
Ok, so I just spent 2 hours mixing with 6.0.1, and another hour earilier with it... so 3 hours total.... I think the program itself hangs.
Here's my reasoning. I would go from folder to folder and while clicking, nothing would load, however everything looks as if it's perfectly fine. This would also make sense as to why the jog wheel doesn't respond at times, and same with the buttons.
Also as a side note: The knob to select songs sometimes doesn't work either. One of the two would.
geposted Wed 10 Jun 09 @ 10:04 pm
I did an almost 2 hour set with about half of that time playing videos. When cueing up the next video VDJ 6.0.1 crashed on me. I restarted VDJ and tried it again to no avail. I had to restart the comp. This has happened a few times. I am a feeder on a couple of Music Groups, someone on one of the channels told me that I can submit a "Crash Report", how do I do this?
DJ RuDe
DJ RuDe
geposted Thu 11 Jun 09 @ 1:41 am
DJ RuDe
DJ RuDe
Go to your virtual DJ folder (C:\Users\YourName\Documents\VirtualDJ\ on windows vista, xp i'm not too sure), and find "Crashguard report.txt". I suppose you'd send in a ticket with the information within it.
geposted Thu 11 Jun 09 @ 10:31 am
Yeah it's Vista. Kool Thx!
RuDe
RuDe
geposted Thu 11 Jun 09 @ 2:22 pm
You don't need the long filename, just go to your Documents folder (Vista) or My Documents (XP) and within it is the VirtualDJ folder.
geposted Thu 11 Jun 09 @ 2:51 pm
Any word yet on the fix for CDJ-400 scratch wheel issue? Not being impatient just curious if it's still in the works for the next update.
DJ RuDe
DJ RuDe
geposted Fri 19 Jun 09 @ 4:22 pm
I am running virtual dj beta 6 for the mac os with two cdj-400s and cannot seem to find a way to get sound output out of both players (they both play out of a single channel)
I have a friend that uses the windows version and it gives the option of an ASIO driver, but my mac version does not give me that option.
anything I can do to get both CDJ-400 players to show-up as sound drivers?
geposted Sat 20 Jun 09 @ 6:08 pm
Yes, you can either set up VDJ with "Two Soundcards" or create an Aggregate Device (click for info on creating one).
geposted Sun 21 Jun 09 @ 3:03 pm
Dj Jamm Here
It appears I offended CHris , Sorry Chris Didnt mean to offend you .. as for a bit of backround Ive been djing professionally for many years. I currently reside in a Very Popular Nightclub in Pittsburgh. Ive used vdj for years recently I purchased the cdj 400s about 2 months ago hoping to have an alternative to lugging tables but have found them to not play well with any config-- , well I downloaded vdj 6.01 and installed it on my gig machine DELL PRECISION WORKSTATION windows xp 2.7 dual core processor 512nvida fx2700 video card 4 gig of ram ( xp uses only 3.2) well With new version It seemd ok i played with it experimenting with audio output and remapped a few functions( the new mapper is graet vdj grt job ) after 3 days it seemed fine at home( btw my vsta backup notebook would not play well)- i took it out this past friday night at the club I work.. i could barely get through the night.. the cdjs lagged so badly and i also couldent keep the waveforms from floating ..also out of nowhere the cue button stopped working and sometimes would respond way after the fact and the scratch, well we know they are working on that, i even adjusted audio settinds on the fly-- but for a professional application it was disheartening for me and i feel like an asshole along with a lot of money spent...... I am selling the cdjs I was looking forward to the denon 3700s. Im am prayng the denon 3700s issue gets fixed... I would love to highlight vdj at the club i work but i do a lot of mixing and I need hardware to work, and not have issues -- I just cant continue to buy new controllers and have issues, (the hercules are great but for a clubgig on weekly basis thats not going to cut it, so far the xp10 has been the best controller so far - i now have isseus with... So you see i have bought many different hardware pieces dac3, numark dmc2 ,denonhc4500 and the herc etc .. Im sure im not the only one out there that is frustrated. Im going to try and hang on to vdj but at this rate it has to be understandable why I am so frustrated, please don't mistake this rant for anything against vdj I love the program,I am asking this to Anyone who can help and Pioneer--> can you help vdj out to make the cdj 400s work correctly i know and you can ask others who have the 400's the cdjs do work fin fine with other programs ..what is necessary for vdj to get it working correctly-- As For Me I cant wait any longer , the longer i do the more money i lose im selling the 400s now but hope the issues get work out for the poeple who have these players. $1400.00 on hardware they cannont use is not my idea of fun ( I feel their fustration) Hell I would gladly pay vdj a fee for getting the bugs fixed on these or any other controllers.---> VDJ is a great program I love it and have been faithful to vdj because its customizable more redily than other programs and its different l.. Im just not a computer Genius Im a DJ and i want to DJ, not spend hours and days fighting with gear -- As A Dj I need more plug and play effectiveness..
Please understand this I dont want to Give In to Serato and all the hype of how grt it is, I am loyal to vdj. I wish to keep using Vdj Please understand this before somone gets offended and attacks me personally like previously .... Im not writing this to in any way put down VDJ, or personally offend anyone, but ongoing issues such as these need to be a thing of the past.. If something is considered native it should work PLUG N PLAY..
. .. if anyone is interested in a pair of cdj 400s in like new condition and in northeast united states let me know. mine are for sale with a nice marathon coffin already wired with plugs and a connection on back so you can hook 1 extension cord right in back and your all powered.. also i am selling a denon HC 4500 used 2 times( grt controller) thanks for listening.. i hope not to offend anyone but Im seriously tired and frustrated
DJ JAMM
DJ JAMM
geposted Mon 22 Jun 09 @ 3:37 am
Set-it up thru Aggregate device as you described. Chose pioneer cdj-400 as one player then my Aggegate device as second player and works like a charm! You are a genius!
geposted Mon 22 Jun 09 @ 4:21 pm
Hey Jamm, I don't understand why you are having so many problems using VDJ with your CDJs. Mine work flawlessly except when it comes to scratching. I have run mine for hours on end using VDJ and not once expeienced anything close to what you are reporting. I really don't know what to tell you here, very strange!
DJ RuDe
DJ RuDe
geposted Mon 22 Jun 09 @ 7:18 pm
I'm running 2 CDJs along with a Korg Zero 4... no problem besides the scratching.
I also noticed that the cue button "sticks" and sometimes doesn't register, and the play button is delayed... but that's more latency then anything (my vdj 5.2.1 had no problems).
I hope they fix it soon :)
geposted Mon 22 Jun 09 @ 11:07 pm
