I was going to purchase virtual DJ and also get a pair of pioneer or numark cd table top players. I know this is pioneer forum, but i did not want to post this twice, in two different forums.
I want to know how to use the players with midi? I guess I dont understand
with Midi, you dont need the time code?
I was using the virtual DJ demo, and everything was working great on PC mode
what are the advantages to spending extra money to get CD players? I think its good to have CD players at my gig , as a backup, but what advantage as a DJ will it give me to get cdj 400's or numark idx
I hook them up directly to the laptop, via USB right? each player into a different USB plug?
the pioneer cdj 400 - it says they have a built in soundcard - how does that work? Do I need to purchase a unit like maya44 or serato box, etc..
thanks
dj naveen
thanks
dj naveen
geposted Thu 13 Aug 09 @ 1:29 am
With CDJ-400s you do not need anything extra to run Virtual DJ. The CDJ-400s when connected to your laptop will automatically begin installing the USB drivers. Then you will go into the VDJ "Config" menu and set up your sound settings and that's it! With VDJ 6 there is no need to MIDI map or anything else since it automatically detects the controller you have connected to it. It is all HID controlled, no need for timecodes and you can tweak the settings to match your needs if you want to.
I would recommend CDJ-400s to anyone.
DJ RuDe
DJ RuDe
geposted Thu 13 Aug 09 @ 2:53 pm
I second that! I also have the cdj-400's and they work great for me :)
geposted Thu 13 Aug 09 @ 9:57 pm
CDJ-400 work indeed very well with vdj.
I just would like to change a bit how the fx buttons and the reloop button work. I'd like to assign the reloop button to activate hot cue, samples, and effect functions, in a cycling way. And then fx buttons would load three functions of the active function.
This way I would neet to touch my pc at all while Djing.
geposted Fri 14 Aug 09 @ 3:16 am
Hey Guys...
I am currently mapping my cdj-400 to VDJ would like some help to perfect it.....I want to map a button so that I can stop and start (pull-up) a song from the begining....I tried using "pause_stop" but this takes me back to the cue points first.
Is there a script that will allow me to do this?
Thanks in advance
Scala
Thanks in advance
Scala
geposted Fri 14 Aug 09 @ 4:42 am
I just added a video on YouTube regarding using CDJ-400s with Virtual DJ...
DJ RuDe
geposted Sun 16 Aug 09 @ 2:57 pm
i have vdj dc that came with my rmx but do i need to download vdj pro to use the thing after the demo is over?
geposted Mon 24 Aug 09 @ 8:25 pm
You are a "Pro Ed" user already, I don't understand your question?!
geposted Tue 25 Aug 09 @ 12:56 pm
the CDJ scratch latency issues solved in 6.0.2?
geposted Sun 30 Aug 09 @ 12:30 am
Not yet, it's closer though. I did a video that hopefully will help for the next release...
DJ RuDe
geposted Sun 30 Aug 09 @ 12:36 am
