mojo3467 wrote :
Can anyone provide a list of all the features that are natively mapped to the Pioneer CDJ 400's using VDJ?
You can see a full list by going to CONFIG -> Mappers and choosing the CDJ400 from the drop-down list. If the CDJ is not connected, you will need to click on the button to the right of the drop-down and untick 'Show only connected devices'.
You can map any button to any function of your own choice via the Mappers tab - Please see http://www.virtualdj.com/wiki/VDJscript.html for further info.
geposted Mon 22 Feb 10 @ 12:27 pm
haydos wrote :
close virtual dj
leave CDJ's on and connected, and uninstall cdj usb sound cards from device manager (windows xp)
turn off cdj's
on your computers usb ports, swap the usb ports that your two cdjs are plugged into
turn first cdj on, let it reinstall
turn second cdj on, let it reinstall
connect them to pc/midi mode
open virtual dj
close virtual dj
turn off cdj's
open virtual dj
If you are 'reloading' the drivers then that is exactly what you should do with any hardware where there are 2 of the same kind. Whether its the CDJ-400, CDJ-900, CDJ-2000, Denon S-3700s, etc. So this is not a VirtualDJ thing as much as it is a proper way of installing the drivers.
Btw, I looked back at your other posts and if the decks are ever 'swapped' - Left one controlling the Right deck in VirtualDJ and Right controlling Left. Then just press the EJECT button to swap them. This goes for ALL tabletop CD players regardless of brand. This is the STANDARD mapping if you are using the VirtualDJ supplied mappings.
As for these units that you can use the built-in soundcards - specifically the 4 I mentioned above. If you choose to use the sound cards on-board the units for your VirtualDJ outputs then you CAN NOT use the CD mode or USB-stick (HDD) mode that are on those units. When you swap out of the MIDI/Audio card mode it disengages the sound card from the computer. This would be just like unplugging your soundcard from the computer while VirtualDJ is playing. That is why when you switch out of LINK/MIDI mode your interface locks up.
geposted Mon 22 Feb 10 @ 4:40 pm
thanks cstoll.
i found a helpful article regarding USB soundcard hardware IRQ's etc here...
I'm going to check it out very soon.
http://www.virtualdj.com/homepage/xeon/blogs/1920/Windows_XP_Optimization_Guide_part_2_(audio).html
However, regarding your comments about both decks having to be engaged in PC Midi for virtual dj to continue working, this isn't the case.
At least.... not some of the time for me anyway :)
I played a whole night at our local club a few weeks ago with another dj, who was using CD's only (those shiny round things).
We only used one set of CDJ400's, (a DJM800 mixer obviously) and my macbook pro.
When I had finished my 30 minute set, i would crossfade over to (eg) the right deck, and he would switch the left deck over to CD mode and cue his song up. Then he would crossfade to the middle and begin his track.
I would continue looping and fully controlling my last track in virtual dj until he had fully crossfaded over, and then he would switch the remaining deck to CD mode.
We would swap back another 30 minutes later.
I had done the same thing 4 weeks ago with another DJ, but with a set of CDJ2000's.
if what you're saying is correct, as soon as they disengage PC/Midi mode on one player, I should lose control of the other player in VDJ.
But I don't (when it's working).
DO NOTE THOUGH, that if I pull the USB cord out of my laptop to a CDJ that is in CD mode, as in, physically disconnect the player, even though it is out of PC/Midi mode, THEN Virtual DJ locks up and crashes (understandably).
I should post a video of it; of me chopping and changing from PC mode to USB mode to CD mode.
Both when it's working (and how convenient it is).
And then one when it's not (and how annoying it is).
It's not so much an annoyance for me, but i think the issue is important for the future integration of Virtual DJ on laptops into clubs, as it won't be long before CDJ2000's start appearing everywhere.
Without this engage/disengage situation working flawlessly, serious DJ's using VDJ are going to have a headache of a time.
Cheers.
Cheers.
geposted Tue 23 Feb 10 @ 4:15 am
Can someone from Pioneer do some testing on this issue, using either CDJ400's, 900's or 2000's.
And let me know their results?
geposted Tue 23 Feb 10 @ 4:18 am
Thanks for your help I will try your suggestions!
Jeff
geposted Tue 23 Feb 10 @ 4:26 pm
Quote :
It's just you, I've tested combinations of CDJ2000, CDJ900, CDJ400, MEP7000 ... never had any problems with drivers or control.
geposted Wed 24 Feb 10 @ 12:25 am
thanks Pulse.
So, just to be sure, you can be playing in VDJ on both decks (400/900/2000), switch one player over to CD mode and start playing a CD, and still fully control VDJ on the other deck?
geposted Wed 24 Feb 10 @ 3:38 pm
I own a pair of the 2K'S myself,yes the other deck still works.A function that you do lose though is if you insert a flash drive or sd card you can't use the link and search on opposte deck to load music from that device.Once the players are linked with the computer they can't be linked with themselves.
geposted Wed 24 Feb 10 @ 5:45 pm
thanks for your comments jack.
it seems it might be an issue relating to me; although i have a macbook pro 13" with windows xp professional on bootcamp.
hardware wise i consider the macbook and cdj's with usb support to be the ultimate combination
i'll be interested to see if anyone else has the issue, or whether the issue appears for you at a later date.
cstoll, in regards to your comment earlier, can you clarify: what is virtual dj 'supposed' to do when one player is switched to an alternate mode like cd or usb?
geposted Thu 25 Feb 10 @ 2:40 am
sorry vdj team to bug, but can you answer my last comment>
cheers,
cheers,
geposted Mon 01 Mar 10 @ 6:14 am
I was testing CDJ-2000 with a Mac and Mac OS. I put a CD in one and VirtualDJ on the other, also change with soundcard while VirtualDJ was playing. I have no problems to report...
You are using bootcamp and XP. If you don't have all drivers (video, audio, etc) for your mac (that is tricky to find on internet) maybe that could also affect the way you are working with your USB ports. Can't be sure but it seems that way for me.
If you can, try with another computer, just to test, If it is a PC with Windows and all it's drivers installed, maybe you don't get this problem. Also you can try with a Mac and 10.5.8 OS or 10.6.2.
geposted Wed 03 Mar 10 @ 10:22 am
Hi
Where do I get version 6.0.6?
geposted Fri 05 Mar 10 @ 12:36 pm
Version 6.0.6 was only a Trial Version update to fix a problem in the Trial Version.
geposted Fri 05 Mar 10 @ 12:51 pm
Is there an info page anywhere that can run me thru setting for my cdj2000 link to vdj?
geposted Fri 05 Mar 10 @ 12:58 pm
You use the documentation from Pioneer for connecting the CDJs to a Computer.
geposted Fri 05 Mar 10 @ 1:25 pm
How do i get both the cdj400's working (sound out of both units) with my mac. please give full description if you are talking about aggregate device as I haven't a clue about that.
Thanks
Thanks
geposted Sat 06 Mar 10 @ 6:35 am
It's not so difficult, just go to were is PANEL SOUND MIDI options and in there you will see your Pioneer CDJ-400 as a sound card device. Then you choose AGGREGATE DEVICE and in there select Pioneer CDJ-400 (and you choose a name now for this new AGGREGATE DEVICE you are setting up; default is CDJ-400 AGGREGATE). You will have some audio channels you could select to work with these devices (2 CDJ-400 for example) and select 4 channels to your aggregate device. Save settings, close windows and go now to VirtualDJ, then select as your audio device PIONEER CDJ-400 AGGREGATE and you will have both CDJ-400 working as sound cards with Mac and VirtualDJ Pro.
Hope it helps you to complete it easy. I Check on this on OS 10.6.2. 10.5.8 you don't have to do nothing at all VDJ could work with CDJ directly.
geposted Sat 06 Mar 10 @ 3:20 pm
Do I have to map all the buttons for my CDJ2000's to work?
The only option I have under mappers is simple midi.
geposted Sun 07 Mar 10 @ 7:22 am
Then you have not LINK'd them correctly before running VirtualDJ.
You must put the units in PC connected mode before running VirtualDJ.
After you power on the CDJ and the computer and have the USB cables connected from CDJ to computer.
You must push the LINK button, then press the TRACK knob to put the unit into PC connected mode.
Then you can open VirtualDJ.
Also, please download the latest version by visiting your Download Center - https://www.virtualdj.com/update.html
geposted Sun 07 Mar 10 @ 10:30 am
Yeah I linked them up and connected to laptop. But the players dont respond to anything unless I start to map them myself then they work...
Will try the new update and give it another go..
Cheers...
Cheers...
geposted Sun 07 Mar 10 @ 11:58 am
