A simple google of 'Pioneer DDJ-Ergo' would have gotten you to the Pioneer website instead of waiting for 10 days - http://www.pioneerelectronics.com/PUSA/DJ/Controllers/DDJ-ERGO
geposted Sun 18 Dec 11 @ 4:01 pm
Thanks for your information, but yes I was checking the site but never knew if the same driver goes for Mac. Lol. I check on Firmware and download.
Thanks for your input
geposted Mon 19 Dec 11 @ 10:47 pm
HI EVERY BODY I NEED SOME HELP WITH MY VIRTUAL DJ 7 AND MY PIONNER DDJT1. HOW I DO TO INSTALL THE MAPPERS AND WHAT KIND OF CHANGES NEED TO DO IN THE AUDIO SOFTWARE FOR IT WORK?
WAITING FOR ANSWERS AND SORRY BY MY ENGLISH
THANKS
THANKS
geposted Sun 25 Dec 11 @ 8:48 am
Hey alejoval,
I have the same problem and I have asked in here for quite sometime- No one seems to have an answer or is interested in answering- Good luck man - Let me know if you get anything on the ddj t1. I have a macbook pro- I guess you have the same setup.
So- anyone in here can tell us how to get the DDJ T1 working.
Its been a month since I bought it, and the Pioneer people here said it has mappers that can be downloaded and works fine- I just can't seem to make it work.:(((
geposted Thu 29 Dec 11 @ 7:35 am
For the Pioneer Ergo. Probably stupid question. Want to make certain before I buy it.
How many sound cards does your PC laptop need in order to be able to cue with headphones with the Pioneer Ergo?
Thank you.
Thank you.
geposted Tue 03 Jan 12 @ 9:19 pm
None.
The Pioneer DJ ERGO has its own built-in multi-channel DJ sound card for master and headphone output.
geposted Wed 04 Jan 12 @ 5:21 am
Got my DDj-Ergo Work VERY WELL VDJ the scratching & VERY VERY NICE it work just like a turntable (basic scratching on the fly)for me .There was only one thing I didn\'t like about the controller ( DDj-Ergo )@ 1st, It will go to to factory setting on the Effects and change some of your pre-setting of your effects that you have previously set so.I had to un-mapp all the FX1&2 CONTROL dial so that it will not change my effects pre-sets, and if the SYNC doesn\'t work or some of the features after mapping it.I all ways Rescan for New Devices after I set my sound setting.On the Filter dial do not un-mapp it,it will make your lights on your jog dials light up non-Stop.
geposted Sat 28 Jan 12 @ 11:07 am
Helloooo,,
i have a svm-1000 do you have a mapper for this machine...
geposted Thu 02 Feb 12 @ 9:34 am
i use pioneer cdj 850 and djm 700 with virtual dj 7 pro in HID configuration. everything works fine but i don't know what happens after playing sometime.. sound stops to come from speakers though song is playing on virtual dj, and when i reduce the volume of the song playing on virtual dj to zero and then put volume again to full on virual dj, sound comes.. and it happened many times in my gig. i tried everything.. from putting latency to safe mode to killing unnecessary processes running on my laptop.. but no use.. updated the firmware in cdj 850's... my pc- sony vaio, 4 gb ram, pentium i 3 processor and i dont have anything on my laptop just songs to be played in a gig... please help me.. do i need to buy maya44 soundcard for getting rid of this problem..
geposted Wed 08 Feb 12 @ 11:39 am
From VDJ's viewpoint, what would be the ultimate Pioneer interface? SVM1000 with CDJ2000? MEP with SVM1000?
geposted Tue 14 Feb 12 @ 9:39 pm
I have had the CDJ850s now for about a year and have never had a problem with them. Are you using a legitimate version of VDJ, if so you should really register it on this site and update to the latest version (b380), if not and you are using a cracked version you will have issues as it has been broken to work for free!
geposted Wed 15 Feb 12 @ 6:55 am
Thanks Chris
geposted Thu 16 Feb 12 @ 7:36 am
Hello VDJ family and Pioneer DJ users! I just want to share the link I have in "general Discussion forum" about my problem in recording mixes.
I decided to post this link here because most of the posters here are using Pioneer Dj equipment.
Link: http://www.virtualdj.com/forums/160903/General_Discussion/Need_help_recording_my_mixes___.html?page=1
I hope you guys can help me.
Thanks in advance!
Happy Mixing!
Ariel
Thanks in advance!
Happy Mixing!
Ariel
geposted Sat 18 Feb 12 @ 11:02 pm
I am using virtual dj 7.0.5 pro,it possible to scratch with virtual dj using pioneer ddj s1 controller? All other functions work with it except for the scratching. i adjusted the jog sensitivity, i am now able to scratch a lil if i hold the platter for a bit then try to scratch again it doesn\'t work i have to search again for a next scratch point and the same thing happens all over again.
geposted Sun 26 Feb 12 @ 8:34 am
HELLO Pulse: ive had this msg up for a week now, 51views and no replys, maybe you can enlighted me> thank you for your help!
Dropped the ergo off at pioneers satellite repair shop yesterday, i dont know what happened but, i changed the latency under configure and it start to sound really bad(lots of static and popping) closed out virtual dj and re-opened and the asio driver was not there at all! un installed and re-installed, updated driver and firm ware. opened virtual again the asio showed but the sound was worse. called pioneer tech support and they said it was a hardware problem. anybody have any thoughts? CONFUSED!!!!
geposted Tue 28 Feb 12 @ 5:47 pm
Guys and gals, if you're having problems with the unit not responding properly (control-wise), chances are you haven't updated the firmware to 1.1 (current as of this posting).
Get it here:
http://pioneerdj.com/support/product.php?c=297&lang=en&p=DDJ-ERGO-V&t=68
This applies to both Mac and Windows users.
Get it here:
geposted Wed 14 Mar 12 @ 10:47 pm
has there been any headway on the latency issues with the DDJ-S1 for scratching. and yes i know about adjusting them and changing settings but all that does is "move" the file with platter manipulation, that is NOT scratching. if i can't do a simple stab with it then there's an issue. other than this problem i haven't noticed any other major issues with this controller. if i could just scratch a little with it it could be club worthy.
geposted Tue 10 Apr 12 @ 10:08 am
Hello
i got a little question i am using the ddj ergo and i wanted to use it with my Notebook, so connectet it to the notebook and everthing works perfect(VDJ 7.05b) but there are a lot of interferencies on the headphones (HDJ-500 i connected them to the ddj-ergo). i tried everything with the the same settings on my desktop PC and on this one are no interferencies.
I updated the firmware of the ergo
hope someone got an idea
thx for helping
thx for helping
geposted Thu 12 Apr 12 @ 10:11 am
Do you have the notebook pwered from the mains supply?
If so, the interference could be coming from the mains adapter PSU.
Try running the notebook from the battery. If the interference goes away, then it's coming from the PSU.
geposted Sat 28 Apr 12 @ 5:19 am
My DDj-Ergo the Vinyl pulse on/off mode only works with some skins, to scratch with ? Or that just a bug in VDj-7.5b.
geposted Mon 30 Apr 12 @ 5:26 pm
