Hi,
(i'm using clipbank with multiple instances)
Clipbank 2.dll + Clipbank 2.ini + Clipbank 2.bmp (= copy from bank1 & assigned other video's)
Clipbank 3.dll + Clipbank 3.ini + Clipbank 3.bmp (= copy from bank1 & assigned other video's)
on each clipbank we can assign 12 clips. From the first clipbank a screenshot is made and stored as .bmp file.
This is the picture you see in the plugin window of VDJ.
I also made copies of the .bmp files (with other assigned clips) but the problem is that it only shows the .bmp file from the first clipbank, although the picture created for bank 2 & 3 are different.
In this way it is very hard to see the different video's.
I guess this is a bug or am I using the clipbank functionality not correctly?
Why not store the path & file name of the .bmp file in the .ini file?
Would be nice to see a solution or hear how it can be fixed
Thanks in advance
Johan
Thanks in advance
Johan
geposted Tue 10 Feb 09 @ 9:37 am
Nobody has this problem?
Or is no one using multiple clipbanks?
geposted Mon 23 Feb 09 @ 5:30 am
I still use the old Version of clipbank and I have 8 banks, works well, could possibly try it. Available for download in the video effects section.
geposted Tue 24 Feb 09 @ 5:59 pm
can anybody help with this problem because im trying to run 2 clipbanks aswell it work ok it just the screen shot .bmp
geposted Fri 27 Mar 09 @ 8:29 pm
