Hey all...
I have just purchased a Omni Control and I have a trial version of Virtual DJ, because of my serial issue i cannot download the midi mapper, are there any tutorials out there to make the omni control "LEARN" the functions of the virtual dj software...
Thanks...
Thanks...
geposted Thu 12 Feb 09 @ 12:00 pm
murrydesigns wrote :
Hey all...
Thanks...
Thanks...
http://www.virtualdj.com/wiki/PDFManuals.html
You can grab the latest manual here which explains the process.
geposted Thu 12 Feb 09 @ 3:58 pm
Hi there, I got an XML file, which you may load into the General Midi, and activate it. I got it because I just bought the Omni, and it will be delivered to my by March/21.
Please try this out and let me know if it works fine with the keys, knobs and lights.
Where should I upload de XML?.
Best Regards.
Best Regards.
geposted Fri 13 Mar 09 @ 2:16 pm
The lights wont work on a midi mapper - native support will be required which will hopefully be included in the next update.
geposted Fri 13 Mar 09 @ 3:11 pm
