Forum: Old versions
Topic: Turning off AutoGain???
No matter what I set the option to, vdj won't leave my gains alone. I'm using a BCD2000, and I want the knobs to stay zeroed/calibrated. I'm using the moramax mapper. Anyone know if this is possible, please?
geposted Mon 16 Feb 09 @ 5:50 pm
Have you tried disabling Auto Gain in configuration (settings) under options?
Yes. It still auto-adjusts the gain after the track is finished loading.
The only decent setting seems to be Auto+Remember. At least then, it keeps my corrections, but it'd be much nicer to keep it locked to my controller.
I beleive the problem may be that your database has recorded you previous gain levels and it will automatically loads these everytime it a track is loaded.
The only way around it would be to wipe the database - but only do this if your 100% sure it is worth it as it will delete you tags, cue points and everything.
