Hopefully one of the "team" will see this, and jump on it.
I have that installation error again, and would really appreciate it if you guys could fix it, again.
geposted Tue 01 Mar 05 @ 5:59 am
installation error is gone.
now, i get a protection error 32....?
hmm, ive never gotten that one
please help (this is crazy)
geposted Tue 01 Mar 05 @ 6:17 am
Hi,
I suppose your problem is fixed now :)
The more important thing for a good e-service support is :
Open one folder for one problem and use always this folder to contact us. In this way, we can follow the problem and we can read each post and see the evolution to the solve problem on the same page. It's easier for us (and faster for you)
thank you for your patience
Coyote
Coyote
geposted Tue 01 Mar 05 @ 6:44 am
I am getting a very bad crash now.
its when i try to mix out of a loop.
lets say i loop side 1 for 16 bars, and then try to mix out with side 2. it will crash bad, and give off this real annoying BUZZ
like the sound Jim Carrey makes on dumb and dumber when he describes the most annoying sound in the world
geposted Tue 01 Mar 05 @ 7:08 am
COYOTE DJ HEEEEELP I CAN'T LOG ON EITHER TO MY VIRTUAL DJ DUE TO THAT PROTECTION 16. BRO I'M LOOSING MONEY BECUASE I'M AM UNABLE TO DJ.. HELP PLEASE
geposted Fri 18 Mar 05 @ 6:38 am
"If you have any Protection Error Number , please contact:
e-service"
Sorry but it's written at the top of this webpage and it's written everywhere on this forum.
And please don't use Caps Lock to write: it means you are angry. Ask you the question why you have this error and some people not....It's easy to understand
e-service"
geposted Fri 18 Mar 05 @ 1:43 pm
Right: e-service is the only solution.
You probably guess why you got this protection error.
Don't worry e-service will solve your problem quickly.
(Don't hesitate to complete your profile: You created an empty blog)
Regards,
Clax
Regards,
Clax
geposted Sat 19 Mar 05 @ 3:00 pm
@VxLeSTaTxV
please check your soundcard setttings, to make sure its correct
also, you might want to try reinstall the drivers for soundcard, and reinstall Virtualdj
might get rid of the problem
geposted Sat 19 Mar 05 @ 4:27 pm
