When I'm connected to my external monitor/screen, how do I maximize the Video window? All I can figure out - is to drag the window to fit the screen I'm displaying on. And I'm left with a bar at the top saying "Video" with the navigation buttons (looks dumb). How can I make full screen? Thanks!
geposted Sun 08 Mar 09 @ 1:00 pm
in the config menu of VDJ - got to video.
Under tv output you should have a drop down window - if you select the video card (Nvidia etc) instead of "window" that should fix it for you!!
geposted Sun 08 Mar 09 @ 1:55 pm
Thanks you for the reply. Maybe that's the problem - video card. I'm on a Mac...the only option I see in the "Video" tab is "Window". Is that because my video card can not handle it?
Hardware:
Macbook Pro 2.4 GHz Intel Core 2 Duo
4GB 667 MHz DDR2 SDRAM
Mac OS 10.5.6
Or I can run Microsoft XP (PC)
OEM Installed Video Card Details:
Chipset Model: GeForce 8600M GT
Type: Display
Bus: PCIe
PCIe Lane Width: x16
VRAM (Total): 256 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x0407
Revision ID: 0x00a1
ROM Revision: 3175
External DJ Gear:
(2) Pioneer CDJ1000's
(1) DJM-909 Mixer
(1) Trigger Finger
Hardware:
Mac OS 10.5.6
Type: Display
Bus: PCIe
Device ID: 0x0407
Revision ID: 0x00a1
ROM Revision: 3175
External DJ Gear:
(1) DJM-909 Mixer
(1) Trigger Finger
geposted Sun 08 Mar 09 @ 9:51 pm
Hello,
First connect your pc/laptop to the external device (beamer/tv) and THEN startup your pc/laptop.
When you connect to the external device when your laptop/pc is already started, it could be that he don't recognize the external device.
The second step:
An easy way to tell if your computer can facilitate dual displays is to:
Close down an programs or applications
Right-click in an open area of your desktop
Select Properties
In the Display Properties dialog, select the Settings tab.
If your computer hardware can facilitate multiple displays, you will see two (or more) representations of monitor screens.
Click the boxes labeled 1 and 2 ... the resolution and color selection may change (you can set the resolution of each display independent of the other).
Ordinarily, the Primary (1) display is the VGA monitor (on desktop machines) or the LCD Screen (on laptops). Depending on your computer's hardware, you may have more video displays (3, 4, etc. up to 8) available.
Click Display 2 and choose “Extend my Windows desktop onto this monitor”.
The last step is to go to virtualdj and change on the video tab the output to your videocard.
Greetings,
Dj Anthony
The second step:
Select Properties
Greetings,
Dj Anthony
geposted Mon 09 Mar 09 @ 12:57 am
