Forum: Old versions
Topic: ATTN: Audio 4/Audio 8 users
I have tried everything....and I just can't seem to figure out a way to end my usb dropout problems I'm having with my Audio 4.
I've been through every latency setting VDJ offers so I'm wondering if I can attempt to "copy" some of your latency settings to see if it works for me. For those of you who have an Audio 4/Audio 8 working without latency problems....please let me know. Thx
I'm running a Vista PC with 2 gigs memory
Duo Centrino processor
Virtual Vinyl Pro
NI Audio 4 soundcard with asio drivers.
geposted Fri 13 Mar 09 @ 8:55 pm
sischoPRO InfinityMember since 2005
Tell us how you set your VDJ on settings field.
geposted Sat 14 Mar 09 @ 5:46 am
I have the Audio8DJ and works perfectly except on 1 ms latency. Take in mind, did you try DPC latency Checker yet? Also, Windows Vista users usually have to tune their OS a bit to make it work fine...
geposted Sun 15 Mar 09 @ 4:23 pm
Personay, I solved all my problems by switching to windows XP. Vista is a mess and so hungry for resources that when I can no longer use XP, its a MAC for me.
geposted Fri 10 Apr 09 @ 3:00 pm
Actually, if you tweak Windows Vista it will work fine. I don't get any spike anymore. tested with DPC Latency Checker, all bars are short green.
geposted Mon 13 Apr 09 @ 6:37 am
