Well, until native control and my funds allow me to buy the Denon DN-S 3700's, I am using my DVJ 1000s and DJM 800 for video and as my audio setup. I have the M-Audio Connectiv as a sound card and was wondering if anyone successfully has used the DVJ's with timecode CD's? I tried it once a few month ago, but nothing seemed to work right. If you have done this, what settings ect... do I need to do. I am going to try it again this weekend at my house to see if I can get it to work. Thanks for any input.
geposted Thu 19 Mar 09 @ 4:31 pm
Did you set up Timecode as INPUT, Mixer as OUTPUT and ASIO as soundcard??
I suggest you to look carefully at this video:
After all your settings, you need to download this mp3 file and burn it over a cd:
http://www.virtualdj.com/products/timecode/cd.html (Pro grade sound level)
geposted Thu 19 Mar 09 @ 5:43 pm
I will try it, I thought I had it that way last time.
geposted Thu 19 Mar 09 @ 6:00 pm
I use that setup once a month. In fact i'm using them Saturday night. It's just like any other timecode source. Inputs to Time Codes, choose the timecode engine within TimeCode config. I use engine V4. I tried engine V5 a while back and had issues. I have the "Clear Sound" box checked.
geposted Thu 19 Mar 09 @ 6:53 pm
