when is the 6.1.1 demo coming out
geposted Wed 04 Aug 10 @ 3:18 pm
Sorry I cant advise on that im sure it will be available soon.
This topic is for Numark hardware so you may have more luck on the general forum.
geposted Thu 05 Aug 10 @ 8:16 am
gud day guys hope you could help me with this one..
i use virtual dj 5.0.7 crack version befor i buy the numark virtual vinyl now i install the virtual vinyl them uptade it to the new version the problem is all the cue poin the tittle i make in the virtual dj witch i use for morethan a year cannot be detected on the virtual vinyl is the any way i can move them to numark virtual vinyl tnx a lot
geposted Fri 06 Aug 10 @ 6:51 am
I own the Numark Mix deck and it came with traktor LE but i was told that i can midi map it to control any program is this true........
geposted Fri 06 Aug 10 @ 6:32 pm
Non-Licensed Users are not permitted to post email addresses.
Please download the trial version to test with your MixDeck and if you like then you can purchase the Pro version.
geposted Fri 06 Aug 10 @ 6:38 pm
IM NOT EVEN A USER ........I WANTED TO TALK ABOUT THIS SUBJECT BEFORE I BUY VIRTUAL DJ
geposted Fri 06 Aug 10 @ 7:05 pm
Mixdeck is supported in the latest VDJ pro so if you where to purchase you would not need map.
You can also get it in the Cue program (VDJ distributed by Numark)
geposted Fri 06 Aug 10 @ 7:56 pm
Hi, unfortunately because of that you may find that you do not have a compatible version.
The database system is different between 5 and 6.
geposted Fri 06 Aug 10 @ 8:08 pm
Thank you very much.......I will make my purchase a.s.a.p.
I wish we could put an end to all the ----- hackers
geposted Fri 06 Aug 10 @ 8:19 pm
with that being said.........will i have control of the music video mixing abilities through the mixdeck
geposted Fri 06 Aug 10 @ 8:21 pm
Yes you can use video features by linking the audio and video faders in the software.
geposted Sat 07 Aug 10 @ 8:48 am
I have serious issues with my Numark Virtual Vinyl interface. Im using a Macbook Pro, Rane 56 and some Technic 1200's and while Im using Virtual vinyl everything plays fine then for some odd reason what was playing on channel 2 of my mixer pops up on channel 1 I then unplug channel 1 from the interface and it's still playing. I cut everything off turn it back on and it's fine could my Virtual Vinyl box be giving mixed signals?????
geposted Tue 10 Aug 10 @ 5:40 pm
Locate and delete this file HDD/library/preferences/Virtual Vinyl.atomixproductions.plist
Run the software and the preferences will be reset.
geposted Wed 11 Aug 10 @ 7:46 am
Hello i need help i want to get http://cgi.ebay.com/2-NUMARK-AXIS-9-CD-TURNTABLE-PRO-M3-DJ-MIXER-BUNDLE-/280546585590?pt=DJ_Gear_Lighting from ebay i will like to know if this going to work perfect with latest VDJ and mores i want to use Hercules MK2 as my soundcard is that possible or i will need to get a sound card urgent attention is need.
geposted Wed 11 Aug 10 @ 6:31 pm
With Virtual DJ pro this would be a great setup for Timecode DJing.
The RMX can be your soundcard.
geposted Wed 11 Aug 10 @ 6:46 pm
For reference Cue 6.1.2 and VV 6.1.2 are now available.
Including improved mappings for all Numark controllers.
geposted Thu 12 Aug 10 @ 3:54 pm
So I've tried to contact numark directly a ridiculous amount of times to no avail. Neither email nor by phone. Horrible customer service. I do however need help. Unfortunately I believe it will have to be a repair fix, in which case only they can "help" me. After scouring the internet I found this site. So here we are. The audio ports on one of my ttx tables does not work anymore. It just stopped working. I checked all the channels on my mixer, as well as tried other audio cables. everything works fine when paired with my other (working) table. I haven't been able to play in a long time and I miss it. I love my tables and do not wish to buy different ones. I need to know what can be done to fix them. Are there authorized repair places? Do I have to send it to numark? Can I be sent the replacement parts?? Anyone, please help.
geposted Thu 12 Aug 10 @ 5:28 pm
ps, Can anyone tell me if they have actually spoken with someone from numark customer service... And if so, why do they seem so unwilling to help customers? I've read many a buyers comments on other sites confirming how difficult it is to reach them.
geposted Thu 12 Aug 10 @ 5:30 pm
Sorry to hear you have had an issue, this topic is aimed at supporting DJ software/controllers.
Feel free to drop me an email at sbangs[at]numark[dot]com and I will ensure your case gets a speedy response
geposted Thu 12 Aug 10 @ 5:40 pm
Thanks for the respond can i use MK2 as well because i have Hercules MK2 still working perfect but i don't really use it anymore maybe it will be very good for my soundcard and more so are you advicing me to get this http://cgi.ebay.com/2-NUMARK-AXIS-9-CD-TURNTABLE-PRO-M3-DJ-MIXER-BUNDLE-/280546585590?pt=DJ_Gear_Lighting will it work perfect and fine with VDJ pro i will be hoping to hear from you.
geposted Thu 12 Aug 10 @ 9:35 pm
