If you want an answer about a Numark product, the best place to ask is the Numark support forum.
community.numark.com
geposted Mon 20 May 13 @ 7:30 am
DJ TJ 2020 wrote :
I have recently just boughten 2 Numark NDX400s and a Numark iM9. After the fact did i learn that the mixer is not capable of a direct computer hookup.
These CD players and mixer are not MIDI capable and cannot control VirtualDJ directly.
To be able to use them, you would need to purchase the full VirtualDJ Professional and use a timecode setup with a suitable ASIO sound card - Please see:
http://www.virtualdj.com/wiki/What%20is%20timecode.html
http://www.virtualdj.com/wiki/Timecode%20Requirements.html
geposted Mon 20 May 13 @ 11:34 am
nitebeatdisco wrote :
but still my question relating to the dmc2 not working with windows 8 remains unanswered after a month......
The Numark DMC-2 is just a standard HID device (Like a mouse) and doesn't need any special drivers, so should in theory work with Windows 8.
If it doesn't, then there may be a hardware fault and/or compatibility issue with it. Please contact Numark for advice.
NOTE: If you can't find an answer in the forums and/or need a faster response, please open a support ticket: http://www.virtualdj.com/contact/index.html - The forums are monitored by support staff, but priority is given to answering support tickets.
geposted Mon 20 May 13 @ 11:43 am
Any one with knowledge of setting up my numark mixdeck quard with vdj please help me
geposted Mon 10 Jun 13 @ 4:43 pm
Please see http://www.virtualdj.com/wiki/MixDeck%20Quad.html
NOTE: Unless your MixDeck Quad came with VirtualDJ LE included, you will need to purchase the full VirtualDJ Professional to be able to use it with VirtualDJ: http://www.virtualdj.com/buy/index.html
You can try it out in Home FREE for 10 minutes at a time before purchasing: http://www.virtualdj.com/download/free.html
geposted Tue 11 Jun 13 @ 5:34 am
hello
i have just bought the numark mixtrack pro and wanted ot install it with my vdj after going thru all cofig i press apply and it give me a message not enoght channels and it seems not connecting to the comp what shall i do please help me
thanks in advance
Daniel
thanks in advance
Daniel
geposted Thu 13 Jun 13 @ 10:57 am
I need a mapping for the Numark Orbit. Can someone post a mapping for it or tell me where it can get one for Virtual DJ.
geposted Wed 26 Jun 13 @ 7:11 pm
There is not a known mapping available yet. And we have not yet been provided any hardware or info to build a native/official mapper.
geposted Wed 26 Jun 13 @ 8:20 pm
The idea with products like the Orbit is to map it for your own needs anyway.
There are so many possible ways to map the controls that no one mapping will suit everyone.
Also if you map it yourself, you will learn a useful skill for the future!
geposted Thu 27 Jun 13 @ 3:40 am
Simon Bangs from Numark has just told me that they're working on it...
geposted Fri 28 Jun 13 @ 1:21 pm
Anybody...
I have ndx800 and 900 with audio 4 dj sound card...
when I play a song in deck A or B both controllers are in control, meaning if I hit pause on either controller it pauses... if I hit play on either controller it plays, they don't control each side both are in control of A or B...
thanks
thanks
geposted Sat 29 Jun 13 @ 12:11 pm
DjCali wrote :
Anybody...
thanks
thanks
thanks for getting back to me so quickly!!!
geposted Mon 01 Jul 13 @ 10:26 am
geposted Mon 01 Jul 13 @ 12:58 pm
I have Virtual Dj Pro 7 Full and I have Serato Dj Intro...Both Software are not functioning well with my Mixtrack Pro or vice versa. The fader controls the pitch when i move the fader all the way to the left/right, button dont match to whats on the screen, etc....Can you please give me a default mapping for both softwares!
geposted Thu 11 Jul 13 @ 7:49 pm
Please register your Pro serial number to your account http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.)
If your MixTrack Pro came with VirtualDJ LE included then its serial number should entitle you to a discount off the cost of upgrading (Providing that it's not second hand and has not already been used.)
Nobody will give you any mappers to which you are not currently entitled as an unlicensed user. Do not ask this again on the forums until you have registered your software or your account will be locked. Besides, the MixTrack Pro is natively supported, so no mappings need to be installed. To reset it back to the factory default mappings, please see: http://www.virtualdj.com/wiki/Reset%20controller%20back%20to%20default%20factory%20mapping.html
If the pitch slider fails to work until you have moved it around a bit, then this is normal in most DJ software. It's a feature called soft-takeover. Please see http://www.virtualdj.com/wiki/Soft%20Take-over%20or%20Non-MIDI%20Mixer.html
If the slider moves on-screen as you move it, but the position doesn't match, then there may be a hardware fault with the slider (It's sending the wrong position to the software by MIDI.) Please contact the store where you purchased it for for advice on repair/replacement.
geposted Fri 12 Jul 13 @ 4:41 am
i have a numark n4 with vdj pro 7.05. its hard for me to explain the problem but i uploaded this video to show you the problem im having. this is the link https://www.youtube.com/watch?v=ZvyqT_GfY3k&feature=youtu.be. take a look at those EQ knobs and pitch fader as the volume changing.
Thanks!!
Thanks!!
geposted Sat 20 Jul 13 @ 11:30 pm
First of all, VirtualDJ v7.0.5 is an old and out of date version of the software. There have been many changes and improvements to the software since then (See http://www.virtualdj.com/wiki/VirtualDJ_History.html ) - We are now on v7.4
As above, please register your Pro serial number to your account http://www.virtualdj.com/users/edit.html and then upgrade to the latest v7.4 version: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are a working DJ and are making money as a result of using it at your gigs.) You can upgrade from your VirtualDJ LE for N4 at a discount.
From your video, there is most likely a hardware fault with the N4 if the knobs/sliders are moving randomly like that. If it's under warranty, take it back to store for replacement/repair, otherwise try using contact cleaner spray on all the affected knobs/sliders: http://www.virtualdj.com/wiki/Button%20on%20MIDI%20controller%20does%20not%20always%20respond.html
geposted Sun 21 Jul 13 @ 11:01 am
Hello.
We have owned the Numark NS7 since about a week into its release but just recently have been having issues with it connecting via usb. The port on the back of the unit has loosened over the years and I don't know if it has lost connection with whatever it is supposed to be touching inside or what could be the issue. Sometimes we have a connection, sometimes we do not. Most recently we have not and/or I've been afraid to use it at jobs in case I lose the connection halfway through the night.
Has anyone had any experience with this? It is obviously out of warranty being that it was purchased around 2009 (my guess). So I don't know if usb ports just go bad and maybe I could solder a new one on the board (actually have someone who knows what they are doing, do it) or if there are other solutions other than buying a new one.
Thanks and Best Wishes,
Danny
Danny
geposted Wed 24 Jul 13 @ 4:32 pm
This is most likely due to wear and tear unplugging and plugging in the USB cable over time.
The only solution is to take it to a repair shop or suitable qualified electrician so that the USB socket can be repaired or replaced if necessary.
geposted Wed 24 Jul 13 @ 5:58 pm
I have the mixtrack pro 2 with vdj pro when i use the effects on 1 deck i.e the brake or rewind effect it affects both decks so if im in a mix and use the rewind effect it ruins the mix by rewinding both decks instead of the 1 deck can any1 help and lemme no what i have to do to correct this problem ?
geposted Sun 28 Jul 13 @ 10:03 am
