Is there a way to save a que point for a song permanently?
I set a que point and then when i start VDJ at a later time, the que point is not set.
Thanks, Rod
Thanks, Rod
geposted Wed 09 Mar 05 @ 10:12 pm
Hi,
A cue point is automaticly saved on the song database when you choose it, if you loose it it's maybe because you have renamed/edited this song or you have modified/crashed your VDJ database
Coyote
Coyote
geposted Wed 09 Mar 05 @ 10:23 pm
Be sure to backup your db when your through scanning and setting cues :)
geposted Wed 16 Mar 05 @ 2:52 pm
