Yo!
I'm proud to announce the first release of MultiFunction 4.x !
This versions have all the features of MF3 http://virtualdj.com/addons/2448/Multi_Functions_variations.html and:
-New 1440x900 resolution
-Separated waves mode
-6 Hot CUEs available on the main screen
-Pitch range can be modified directly from the skin
-Key display
-Key slider
-Key jumper
-Beat skip
-Timecode modes can be switched directly from the skin
-MIC level slider
-Master BALANCE slider
-Comments are displayed and can be modified from the skin
-CPU bar more discreet
I hope you'll enjoy it!
SQ;p
PS: This skin took me a lot of work and time (since V1.0). So, if you like it and/or if it's allow you to rock the dancefloor (!), do not hesitate to make a little donation! It will help me to continue this work.
Thank you!
-Key display
-Key slider
-Key jumper
-Beat skip
-MIC level slider
SQ;p
Thank you!
geposted Fri 24 Apr 09 @ 2:31 pm
your skin doesn't display cues over the little waveforms.
geposted Fri 24 Apr 09 @ 3:01 pm
On the right deck yes, thank you, I'll fix it. That's what a Beta version is made for ;)
geposted Fri 24 Apr 09 @ 3:17 pm
No more bugs?
geposted Sun 26 Apr 09 @ 10:58 pm
