Forum: Old versions
Topic: VDJ Just crashed, have a gig tonight!
Crash ID=76a3e12d (date=903291507, version=5.2.1 Pro, build=521, thread=Main, dump=81792820, excode=c0000006 (0,29e0028))
Freeze (date=903291507, version=5.2.1 Pro, build=521, thread=Screen)
Crash ID=76a3e12d (date=903291507, version=5.2.1 Pro, build=521, thread=Main, dump=81792820, excode=c0000006 (0,2840028))
Crash ID=7782e12d (date=904011811, version=5.2.1 Pro, build=521, thread=Main, dump=81792820, excode=c0000006 (0,38a0028))
Freeze (date=904011811, version=5.2.1 Pro, build=521, thread=Screen)
Crash ID=002cdea0 (date=904251225, version=5.2.1 Pro, build=521, thread=Main, dump=88449204, excode=c0000005 (1,ff7c14))
Should I be concerned, I have a gig tonight?
Syberman
geposted Sat 25 Apr 09 @ 11:29 am
Just crashed again! Second time in a few hours. I have a gig tonight, I hope it doesn't crash tonight!
Crash ID=77169f2e (date=904251335, version=5.2.1 Pro, build=521, thread=Main, dump=66833800, excode=c0000005 (0,254504))
Syberman
geposted Sat 25 Apr 09 @ 12:38 pm
DHoudePRO InfinityMember since 2009
I can't read those things, but have you disabled your firewall, anti spyware and anti virus programs? I know this is not much advice, but I have forgotten to do that a few times.
If that is not it, maybe try a different skin, just in case.
geposted Sat 25 Apr 09 @ 12:48 pm
taylaPRO InfinityMember since 2007
daft question but have you put in a ticket, it's the weekend so don't know if it would be even ok to try and pm the obvious choices, hope you get it sorted in time mate...
geposted Sat 25 Apr 09 @ 1:08 pm
mp3jrickPRO InfinityHonorary MemberMember since 2003
There is only one teamer DJ Cel that keeps a log on the crash codes.
In the meanwhile, try disconnecting any hardware controller you may have and see if things improve.
As DHoude said, try the default skins also until its figured out.
geposted Sat 25 Apr 09 @ 2:19 pm
djcelPRO InfinityModeratorMember since 2004
They are external crashes and freezes
Maybe your drivers (video drivers I guess in your case) or an issue with your HD.
Disable the fullscreen mode of the skin if you use it.
geposted Sat 25 Apr 09 @ 3:12 pm
