Forum: Old versions
Topic: Virtual DJ 5.2, Hercules MK2 and Vista
Hello,
I am using Virtual DJ 5.2, Hercules DJ Console MK2 and Vista. After reading some guides here I have managed to get rid off the DirectX-poblem.
But... now I can't here music in Deck A and Deck B, only in Mix and Split.
What to do? I have all the latest drivers and firmware.
Thanks.
EDIT: It seems like I have the same problem when I'm playing with Traktor 3.
geposted Wed 29 Apr 09 @ 2:15 pm
DJ PhatsoPRO InfinityHercules Support TeamMember since 2005
Have checked the soundcard configuration in VDJ ? Be sure that you are are set as follow:
Input; NONE
Output(s): Headphone
Soundcard: DJ Console MK2
Same thing for Traktor:
Main out: output 1/2
Monitoring Output 3/4
geposted Thu 30 Apr 09 @ 7:44 am
djsyn7Home userMember since 2009
you probably are doing exactly the stupid same thing i did for about 2 weeks after buying my mk2 hahaha.....u only need to connect the 1/2 output....the 3/4 is for the headphones so don't connect anything there at the back and ure headphones as usual at the front, hope this helps...
geposted Sat 06 Jun 09 @ 11:55 pm
need help my dj console mk2 isnt working for the 6.0 .works with all the others..need help with it thank you
geposted Wed 10 Jun 09 @ 3:54 pm
