Forum: Old versions
Topic: Please help- Using an external hard drive!
Okay so I have Virtual DJ 5.1 Pro: I've been using my hard drive to mix in the past but just recently bought an external so I could take it on the road. I"ve copied all my music as well as all related Virtual DJ files to the external, including the database (which I also tried re-naming). I tried it now on a different computer and all of my Virtual Playlists, BPM's and custom titles/loops are gone. How can I fix this?
geposted Thu 30 Apr 09 @ 11:58 am
Okay so I found the database now, my only problem is it won't locate any of the files.... Can I sync the actual files with the bpm tags and such?
geposted Thu 30 Apr 09 @ 12:37 pm
djpr1PRO InfinityMember since 2008
just make sure that when you copy all your files and database from the previous drive to the new external drive is in the same location as the previous drive.
the only thing that it will change is your new drive letter.
geposted Thu 30 Apr 09 @ 2:36 pm
