Hye,
My name is Danny.
I am new here.
Yesteray I have bough a Dj Console.
Iwould like to mix with Virtual Dj.
But when I open the software (delivered with hercules dj console "DJconsole 1.09 special version") i get an error:
"Error in the sound driver of DirectX"
When I use the trail version and I put ASIO off I get "protection error 32:please contact --@--.--"
What can I do ?
Please help me.
I would appreciate that very much.
Thank You !
Greets,
Danny Vanhove
Moderated by Lady Cameron
Sorry Ajax_is_the_best no email address is allowed from a demo user
My name is Danny.
I am new here.
What can I do ?
Please help me.
Thank You !
Greets,
Danny Vanhove
geposted Wed 16 Mar 05 @ 11:08 pm
hallo Ajax_is_the_best.
heb je de laatste direct-x drivers geinstalleerd ?
die staan ook op de hdc cd.
have you installed the latest direct-x drivers ?
this is also on the hdc cd.
geposted Thu 17 Mar 05 @ 7:06 am
Hey djjb,
Dat heb ik gedaan. De laatste versie 9.0c staat erop.
Waaraan zou het dan nog kunnen liggen?
geposted Thu 17 Mar 05 @ 9:00 am
English please!......Its cool you guys come from the same country but it would be nice for other forum readers to understand what you mean and possibly help someone that has a similar problem.
Regards
Andre
Regards
Andre
geposted Thu 17 Mar 05 @ 12:26 pm
Okey, np !
As I said (in my language):
Hey, djjb
I've already downloaded and installed the newest DirectX 9.0c.
But it still doesn't work. What could be the problem then?
Hey, djjb
geposted Thu 17 Mar 05 @ 1:04 pm
hmmmmm could be your computer does not recognize the console....
Try logging the console in your profile.
Did you have a crack version in your system b4?
Also read the first post in this section of the forum.
Regards
Andre
Regards
Andre
geposted Thu 17 Mar 05 @ 10:13 pm
Hye Andre,
My computer recognises the console and opens Virtual Dj when in NON-ASIO mode... The only problem I have then; there is no sound.
When I select the ASIO mode I get the "error in the sound driver of directX"
I did not have a cracked version before. The software I use, is the delivered version with the dj console. (Dj console Special version 1.09)
Hope you can help me.
Regards,
Danny
Regards,
Danny
geposted Thu 17 Mar 05 @ 10:35 pm
I see your profile has changed.....coool
Now possibly your sound card does not allow support Asio?
Andre
Andre
geposted Thu 17 Mar 05 @ 10:44 pm
Where can I see that ?
Danny
Danny
geposted Thu 17 Mar 05 @ 10:53 pm
Start-control panel-system-hardware-device manager ....check under sound
Is there a yellow triangle showing?
Andre
Andre
geposted Thu 17 Mar 05 @ 10:59 pm
No, there is no yellow triangle showing.
(by the way, In New Dj my console works, but I prefer to use Virtual Dj.)
Danny
Danny
geposted Thu 17 Mar 05 @ 11:07 pm
So there is no conflict ....this should work????????
try this simply unplug and plug back the console
what happens when you do this?
Andre
Andre
geposted Thu 17 Mar 05 @ 11:13 pm
After unplugging and plugging back my console, Virtual Dj runs, my console also.
But there is no sound comming out of my speakers.
Danny
Danny
geposted Thu 17 Mar 05 @ 11:19 pm
Is your console going into a mixer?
Also make sure to change the console to dj mode after start up or connect/disconnect.
Are we getting somewhere? lol
Andre
Andre
geposted Fri 18 Mar 05 @ 7:19 am
@alex
The protection error is most likely because you have tried a cracked version of Virtual DJ. They dont work right, and only cause problems
The reson for no sound / direct x driver error, is because you have tried to set up more advanced soundcard settings with cracked or trial version, and somehow it have messed up your console version
the console version ONLY works with the Hercules console, and ONLY with it set in 4.1 mode
geposted Sat 19 Mar 05 @ 4:41 pm
