Forum: VirtualDJ Skins
Topic: 3 monitor skin pleeeeeeeze!
Hello :0)
I would really like someone who is saavy at building skins to develop a skin that is divided into 3 sections/units:
1-Left Deck & Left Controls
2-Right Deck & Right Controls
3-Center Waveform Display & File Browser
I want to put 3 widescreen monitor stands on my battle coffin to mount at gigs & have each of those mentioned sections allotted accordingly.
Yes, I will have a graphics card that allows for this.
If 3 sections is too difficult, you could make 2 sections, where the Left & Right decks make one that is twice as wide as the Center section. Then I can split my second video out from my computer to two monitors and put them above my CDJ400s & have the other monitor out go just above my Pioneer DJM700.
I know sounds like a lot of work but I like the idea of each computer section being right behind the physical controlling sections that correspond.
geposted Fri 15 May 09 @ 3:10 am
There is a user here by the name of DJNutz who has a system with 3 touchscreen monitors with the decks on the 2 outer and the browser in the middle. Look him up as this is not impossible.
geposted Fri 15 May 09 @ 4:02 am
