Forum: VirtualDJ Skins
Topic: Work xml...
Hello friends, I would like to know information in an xml file to change the color of the waveform and also on the fader where do I change the values?
geposted Tue 19 May 09 @ 1:58 pm
To change colours you will need to change the BMP not the XML.
geposted Tue 19 May 09 @ 3:31 pm
I would like to change only those parts because everything else I have changed, but in the xml file I have found the parameters to do so!
geposted Wed 20 May 09 @ 1:25 am
sischoPRO InfinityMember since 2005
You can change those parts of the skin by handling the .bmp file, not the .xml file.
You only need a Photoshop program or something similar to do that.
geposted Wed 20 May 09 @ 1:58 am
