For some reason I had to rescan all my files and the key is displayed differently and I don't know how to fix it. All my files key's were marked with 1-12 and followed by A or whatever, ex. 12A. Now they have a letter like A-G followed by a M and sometimes have a #, ex. Dm or D#m. How can I change this back to my original key setting?
Thanks Mike
Thanks Mike
geposted Sat 23 May 09 @ 9:59 pm
Just go to the top of tool bar in virtual...put your pointer on it then right click....You have the (key) checked or you have (camelot) checked...just pick the one you like...then uncheck the one you don't.....good luck
geposted Sun 24 May 09 @ 1:42 am
Thanks man. I can't believe I didn't see that. All is good now.
geposted Sun 24 May 09 @ 8:32 am
those are actual keys M or m is maj or minor minor has a minor 3rd ......
for instance ( a ) minor is the related minor to C Maj .....because the interval from a to C is a minor 3rd .....
geposted Sun 24 May 09 @ 12:46 pm
