Forum: Old versions
Topic: VDJ6 & Cue Points
Hi.. Finally V6 is out !!! not that I was having much problem with 5.2.1, but I have been looking forwards to this.
Got it installed on my test machine & immediately noticed that there are only 3 hot cue points & the old cue point interface for adding 8+ cue points is gone.
I read the docs for version 6 & searched the forums, can't find any info on how to add more than 3 cue points... can anyone help me ?
thanks,
Nigel
geposted Wed 03 Jun 09 @ 1:19 pm
As far as i can tell you can still have any number of cue points. I have just tested on my new skin development 4 and 5 hot cues and they all work.
If you are using an older skin anything below 6.0 - then they may not work as some of the coding in VDJ 6 has been changed.
geposted Wed 03 Jun 09 @ 6:16 pm
cstollPRO InfinityMember since 2004
VirtualDJ has always been able to assign 99 cue points ... it just depends on the skin designs and 3 was a number that was picked to display on the default skins ...
How you get more is up to the skins you use or keyboard 'set_cue #' you create.
geposted Wed 03 Jun 09 @ 6:54 pm
