Forum: Old versions
Topic: ATI problem??
At some moments... very often... all the controls freeze-up. I still can control them but they are all freeze-up. So I cannot see where the sliders are. That's the bug. Now I would like to know if it's due to my graphic card (ATI All-in-wonder 9700 Pro 128mb). Cause the software is unusable because of this.
thank you
geposted Wed 06 Aug 03 @ 4:28 am
DJ CocoPRO InfinityMember since 2003
How much RAM?
How long were you using virtualdj ´til the error came?
How big were the files you were playing?
geposted Wed 06 Aug 03 @ 3:27 pm
Yan-XPRO InfinityHonorary memberMember since 2003
I own a ati 9700 pro 128 too with dual monitor outputs enabled and have no problem.
Have you install Ati Catalyst 3.6 ?
geposted Wed 06 Aug 03 @ 6:30 pm
DJ RickPRO InfinityMember since 2003
Give us a more detailed description of your computer.
What processor, what speed, how much ram...
geposted Wed 06 Aug 03 @ 6:35 pm
This problem is related to Hyperthreading and i just made a short test, it seems to be fixed in VDJ v1.03.
I suggest you verify that you aren't using older version. The version number is shown in the logo when you start it. 1.03 demo is already available.
geposted Wed 06 Aug 03 @ 7:12 pm
Holy cow :( I talked too early.. still have this problem, just didn't come out so fast on the first run.
Read the last post of the following topic for temporary solution:
Technical support : Crucial - VDJ acting unstable
http://www.virtualdj.com/forum/display.html?topic=889
geposted Thu 07 Aug 03 @ 12:45 am
Ok...
I got
CPU: Intel Pentium 4 2.6 ghz hypertredding
RAM: 1 Gig DDR PC3200
motherboard: ASUS p4C800
and the graphic card...ATI all-in-wonder 9700 pro 128mb
on windows XP
Voilà! :)
geposted Thu 07 Aug 03 @ 4:59 am
nscodeHome userMember since 2003
The problem is that your computer is too good.
Solution1: Buy a cheaper one and give this one to me :)
Solution2: Disable Hyperthreading
Solution3: Read the post methioned above, there are more solutions there
geposted Thu 07 Aug 03 @ 8:58 am
hehe ;)
But I don't want to disable hyperthreading.
That's not a good idea. :)
I'll wait for a patch.... I hope.
geposted Sat 09 Aug 03 @ 2:07 am
geposted Sat 09 Aug 03 @ 8:17 am
