Hi:
I want to try to develop a plugin using a window to put my own buttons and text box.
Any of you can me provide a little source example how to create this type of window?.
I know how to use the Createwindow() or Createdialog() functions, but need a little example to understand better how to "connect" it with VDj.
Regards
Walter D.
Regards
Walter D.
geposted Mon 08 Jun 09 @ 1:49 pm
Do you know WIN32 API ?
geposted Mon 08 Jun 09 @ 3:35 pm
Yes, I know.
geposted Mon 08 Jun 09 @ 5:04 pm
Implement OnGetUserInterface() and in this function create your window/dialog. Pass the handle of your created interface back via the pointer supplied and return S_OK :)
geposted Mon 08 Jun 09 @ 5:09 pm
http://www.virtualdj.com/forums/99677/Virtual_DJ_Plugins/Source_code_request.html?search=CALLBACK&page=1.25
http://www.virtualdj.com/forums/95726/Virtual_DJ_Plugins/How_to_write_a_CUEing_plugin.html?search=static&page=1.4
Do not forget to destroy the window in the OnRelease() function.
geposted Tue 09 Jun 09 @ 2:44 pm
Thanks, will try to use your help.
Regards
walter D.
Regards
walter D.
geposted Tue 09 Jun 09 @ 6:59 pm
