Is there a way to get the VDJ 6 default skin to show Camelot keys in header by default instead of showing it as the musical key.
If someone can help guide me as its bugging me having to change it all the time.
geposted Wed 10 Jun 09 @ 5:27 pm
Copy the skin you want to edit to your desktop, unzip and open the skin folder.
Open the xml file in note pad and do a search for "%Pkey" remove it and replace it with "%camelot".
Save the changes and close note pad. Select the new xml and the bmp, right click to create a zip file.
Copy that zip file back to your skin folder, open or bring up VDJ and select your newly edited skin.
You should be all set.
geposted Wed 10 Jun 09 @ 8:59 pm
Mouse click on the key value for each player a couple of times.....
geposted Wed 10 Jun 09 @ 11:11 pm
Thanks will give editing the .xml file a go
geposted Thu 11 Jun 09 @ 9:34 am
I forget how that it is coded but you also can try swapping the number in the text line
example:
text1
text2
make it
text2
text1
geposted Thu 11 Jun 09 @ 10:31 am
