Forum: Old versions
Topic: Quick Fix For RMX & Crossfader
Im having a bit of an issue. If i use the crossfader too fast(cut), even though the fader is all the way to the left/right you can still hear the other deck. Fix anyone?
geposted Wed 10 Jun 09 @ 9:15 pm
I did notice that myself even with the last version but it's not the software. This event didn't happen until I downloaded the latest drivers. When this happens all I do is bring it the fader back over slightly and bring it back... This also happens with scratch fade.
It doesn't happen all the time. No some of the mixes may not be as clean because of it but most dancers won't and don't even notice it.
geposted Wed 10 Jun 09 @ 10:04 pm
ciocePRO InfinityMember since 2004
New Hercules driver (coming soon) wil fix this problem, please have patience.
geposted Thu 11 Jun 09 @ 4:50 am
excellent!
geposted Thu 11 Jun 09 @ 5:37 am
aledjoPRO InfinityMember since 2005
i have same problem!
when release new driver??????? :)
geposted Thu 11 Jun 09 @ 6:26 am
this problem have and faders deck a & deck b
please fix this
geposted Thu 11 Jun 09 @ 11:03 am
geposted Thu 11 Jun 09 @ 8:08 pm
how soon?
hurry up hercules team!
i waiting months for this fix....
sorry but my nerves for this problem is bad.
geposted Thu 11 Jun 09 @ 8:17 pm
my friend this is not a VDJ problem, it is a Hercules problem, they made a bad driver.... pls be patient
geposted Thu 11 Jun 09 @ 8:37 pm
I had a feeling that the new driver was not quite right...button actions are also somewhat inconsistent, inputs don't seem to work properly (for non-timecode sources), and pitch sliders are a bit jumpy. Thanks for the news, cioce :)
geposted Thu 11 Jun 09 @ 10:17 pm
DJ PhatsoPRO InfinityHercules Support TeamMember since 2005
The new driver (2009_HDJS_2) is now online.
geposted Fri 12 Jun 09 @ 11:28 am
geposted Fri 12 Jun 09 @ 6:54 pm
with new drivers the faders works but jogs even have problem.....
geposted Sat 13 Jun 09 @ 7:58 am
Hello aledjo,
I suggest you take the time to describe your issue with jog wheels, since as nobody has described an issue with jog wheels, we may not halp you since we don't know what you mean, what is your problem, what is your version of VirtualDJ and what is your setting...
geposted Sat 13 Jun 09 @ 11:38 am
ok.
i use version 6.0.1 with last drivers rmx.
in scratch mode (and cdj mode when song is stop and moving song with jogs), some times the song dont comply with jog speed.
other times the song stuck even jog moving.... and after some msec then comply with jog speed....
this happen some time, not always. (as ploblem with faders older)
mabby is hardware problem of rmx or drivers.
i dont know.
the problem do in deck 1 and deck 2...... isn't problem for one only jog
the problem there always with all version vdj and all drivers rmx.
geposted Sat 13 Jun 09 @ 3:34 pm
Hello Aledjo,
1) Do you get the same symptom on VirtualDJ 5.2.2 DJC?
2) Have you closed all task which consume CPU in the background (as internet access, wifi access, anti-virus)?
geposted Mon 15 Jun 09 @ 5:18 am
1) yes.
2) my laptop for work has win xp + vdj only! (+ mp3), no antivirus, no anything!
this problem have and with traktor.
the problem don't have vdj and other software but hercules rmx!
mabby hardware or drivers-software.
geposted Mon 15 Jun 09 @ 5:44 am
Hello aledjo,
1) Have you the same issue in VirtualDJ when you use the Rmx in WDM mode instead of ASIO?
In the config menu, in the sound setup, you must uncheck the check-box "Apply EQ on external inputs" to switch in WDM.
2) Have you the same issue if you change the ASIO buffer size in DJ Console Rmx control panel?
You must change this buffer size before running VirtualDJ, and then, in VirtualDJ, check the box "Apply EQ on external inputs".
3) Can you run Windows XP system information program
C:\Program Files\Common files\Microsoft Shared\MSInfo\msinfo32.exe
(with your PC set as you set it before starting VirtualDJ) and precise your configuration with answers to the questions
Processor (and speed)
Total physical memory
Available physical memory
Total virtual memory
Available virtual memory
Space for exchange file
geposted Mon 15 Jun 09 @ 8:46 am
