Hi-
I am trying to gain a 3rd & 4th turntable on the same computer so I am trying the local instances option.
The directions are a little sketchy. Here is what I am doing, so far no joy.
Open instance of VDJ. Set Config>Network>IP=127.0.0.1. Open another instance of VDJ. Set Config>Network>IP=127.0.0.1. In both cases the port is 12345 and I am clicking full synch option.
Not working, what am I doing wrong?
TIA
TIA
geposted Tue 29 Mar 05 @ 5:28 am
Your settings are good for multi-instances on the same computer
you need to start the 2 vdj again and press play and beatlock. It's difficult to initialize the network but it works: switch between play and beatlock more times.
When it's ok you can move a pitch (without beatlock on) and the 3 other pitch automatically move if bealock are on for them
geposted Tue 29 Mar 05 @ 1:23 pm
What he means is that beatlock is actually the sync device between both instances.
So just click on/off during your session
Andre
Andre
geposted Tue 29 Mar 05 @ 1:35 pm
That did it, thanks!
geposted Thu 31 Mar 05 @ 12:53 am
HI !!
I'm new at this...I've just bought a mixer and a usd sound card, I've trying to connect it and make it work with the virtual dj for a week and I am not able to set it up.
could anyone tell me how to do it?.THANKS!!!
geposted Thu 31 Mar 05 @ 4:55 pm
Welcome cronik...start here http://www.virtualdj.com/forum/display.html?topic=10347
then use the search box in each forum for questions most are already answered
just enter a key word (USB,Mixer....etc)
Regards
Andre
Regards
Andre
geposted Thu 31 Mar 05 @ 4:59 pm
