Having issues with my VDJ V5.2.1 Pro (Tried V6 as well)
All of a sudden when I'm playing the tracks have a skip in them. Happens continually.
I've recently installed a new HDD but can't see wht that would change anything.
If I listen to the same track through WMP its fine.
Anyone shed any light on this?
Thanks in advance
Thanks in advance
geposted Sat 13 Jun 09 @ 4:26 am
Yes that has been noted, your not the only one :(
geposted Sat 13 Jun 09 @ 6:15 am
Anyway to fix it?
I have tried just about all I can think of except a rebuild but that seems a bit drastic.
geposted Sat 13 Jun 09 @ 8:01 am
Maybe something in this post might help you ;)
geposted Sat 13 Jun 09 @ 8:31 am
Seems okay for me now so I'm guessing the new drive and having 14 windows updates ready to install had something to do with it.
Having said that I notice I have VDj running and its using WDM when it's always used ASIO before????
geposted Sat 13 Jun 09 @ 9:06 am
Just set soundcard to ASIO and choose the Herc from the dropdown.
geposted Sat 13 Jun 09 @ 2:24 pm
Have you installed the new HDD as a RAID array, or independent drive?
It sounds to be a low level system issue, perhaps a bandwith issue?
geposted Sun 14 Jun 09 @ 9:01 pm
