Hi There,
I'm trying to adjust the default VDJ 6 skin to what I think is best for me, but I don't really understand how to deal with this adjustment:
I want the scratchfunction of the jogwheels to be disabled and replace its function for pitchbending (that function is found underneath the pitchfader; arrows)
The standard xml code of the pitch_bend arrows is:
<button action="deck 1 pitch_bend -5% 500ms" rightclick="deck 1 pitch_bend -5% 500ms">
<pos x="465" y="386"/>
<size width="20" height="17"/>
<over x="+0" y="+1400"/>
<down x="+0" y="+900"/>
</button>
<button action="deck 1 pitch_bend +5% 500ms" rightclick="deck 1 pitch_bend +5% 500ms">
<pos x="487" y="386"/>
</button>
I've worked with the Skin Creator Tool (which is an excellent program) but I don't know how to fit this into the jogwheels.
My wish how it's have to work:
- Jogwheels are standing still during play of a song
- Jogwheels are no longer able to scratch
- Jogwheels; while grabbed with the left-mouse-button, nothing is happening
- Jogwheels; while grabbed with the left-mouse-button and turning left, the pitch_bend is slowing the song as long als you keep turning.
- Jogwheels; while grabbed with the left-mouse-button and turning right, the pitch_bend is speeds up the song as long als you keep turning.
- No right-clic function
Is there someone who can adjust this for me?
Thank you very much!
</button>
</button>
geposted Mon 15 Jun 09 @ 2:04 am
You will need to use a slider control with the "nudge" action.
Look at the MixStation skin for an example.
geposted Mon 15 Jun 09 @ 6:45 am
