Forum: Old versions
Topic: VDJ 6.0 Mapper Problems?
I cannot create my own keyboard shortcuts in the new Vdj 6
when i press them whilst mixing nothing happens, even if i try and edit existing shortcuts, nothing happens??
geposted Mon 15 Jun 09 @ 9:27 am
same here man
Well I managed to map my own buttons but how can I choose if its "default deck" or "active deck"?
I have noticed this problem coming up alot around the forums?
Anyone figured out a way around it yet
Go into Config/Mappers tab and select Keyboard from the dropdown list. Select an existing key you want to redefine or click the green "+" on the bottom of your screen to add a new key definition.
Then type the key you want to assign an action to in the Key box, then type the action you want it to perform in the Action box below it.
If you want to perform an action on a specific deck, then specity the deck. For example, let's assume you want to assign the action "STOP the currently active deck" to the keyboard shortcut/letter "q", then enter "q" as your key and enter "deck active stop" as your action.
If you wanted to have this action happen on the default deck, then enter "deck default stop" in the action box.
All you're doing is specifying that the action you enter should be applied to the specific deck you enter in your action box. If you didn't want to be specific about which deck the action was to be performed on, you'd simply enter "stop" as your action. You can also specify individual decks as "deck 1" or "deck 2" (or alternatively "deck left" or "deck right").
Also, ensure you have keyboard shortcuts enabled by going to Config/Mappers and clicking on the icon to the right of the Controllers dropdown box and ensuring "Use KEyboard Shortcuts" is enabled.
Is this clear or have I confused the hell out of you???
Good luck...
-Martin.
Lol, thanks for all that but i think u may have understood the question? Either that or i wasnt specific enough.
I have set keyboard shorvuts etc. etc. i have set my own custom ones and all steps u mentioned before^^ were done.
But wen i press the key in virtual dj nothing happens at all? even though it has already been set.
For E.g
Key:1 Command:deck_1 play_pause
Key:2 Command:deck_2 play_pause
Whe i press 1/2 in virtual neither deck plays, nothing happens
For E.g
OK it would be deck 1 play_pause not deck_1_play_pause....
For E.g
I'm having the same problem.
my shortcuts dont work at all and i'm using version 6.0.1 on vista ultimate.
its totally crippled me and i'm forced to use version 5.2.
Please help!!!
Just wondering if you created a definition file. If you haven't, check out the file I made for the denon x1700. I'm not a programmer, but basically I just downloaded another file (I think the behringer mixer), saw how it was done. Then I went ahead and looked up the midi comands from the denon manual. Once I did that, I proceeded to start mapping.
otherwise, if the controller is recognized, go to mapper and start clicking around. It will create a file called "generic midi map" I hope that somewhat helps.
good luck
