I'd like to enable a button as shift to be able to hold shift and a cue button and to erase a specific cue point, then hold shift and press other cue button to erase that cue point, etc
How do I do this, what is the syntax and what integers need to be used
geposted Fri 19 Jun 09 @ 4:38 am
First up, have you tried my mapper?
If so you could just change where I use set_cue to delete_cue.
If not, set the SHIFT button to:
set "shift" while_pressed
Then the cue 1 (and 2/3/4/5) button to:
var "shift" ? hot_cue 1 : delete_cue 1
See how you get on with that :)
geposted Fri 19 Jun 09 @ 5:21 am
Scott do you have a new mapper for v6?
how can I get it, is it uploaded in the download section?
Anyway I loved your mappers , thank you again
geposted Fri 19 Jun 09 @ 12:53 pm
Yup, it's in the download section. It's a cross between my original mapping and the v6 default mapping.
geposted Fri 19 Jun 09 @ 10:58 pm
