I want to create a simple mapping on my VCI-100 that when you move a knob to the left (down), it cuts the eq_low, and when you move it to the right, it brings it back up to 50%, and then if you keep moving right (up), after 50% it starts cutting eq_hi.
This would be easy if the mapping can detect direction and use conditionals like < > or =
Is this possible ?
Is this possible ?
geposted Sun 28 Jun 09 @ 9:09 am
I haven't tested it yet but maybe by using the word "value" in the command:
"value < 50% ? cmd1 : cmd2"
geposted Sun 28 Jun 09 @ 11:07 am
value seems to work to extract the value, but the operators <,> and = seem to cause syntax errors.
Does the wiki site have reference for all the operators you can use ?
Just found this on the wiki site... maybe what I need
"To set a variable, you can use verbs like "set", "toggle", "cycle".
To read a variable, you can use verbs like "var", "var_equal", "var_smaller", etc..."
geposted Sun 28 Jun 09 @ 2:34 pm
You can use the following with knobs to detect the direction:
param_greater 0 ? action_for_turning_right : action_for_turning_left
geposted Sun 28 Jun 09 @ 4:01 pm
I figured it out via the wiki site, but thanks for that info.
What I used in the end was this:-
param_smaller 51% ? eq_low : param_invert & eq_high & eq_mid
If the knob is at half or less, and you turn it down, you get eq_low, if its at 51% or greater and you turn it up, you get reverse eq on high and mids..
PERFECT! Now just to add a flanger effect and you'll have a cool transition effect.
geposted Sun 28 Jun 09 @ 5:24 pm
