Forum: Old versions
Topic: Disabled Karaoke plugin + enable slideshow and sonique plugin = lockup
I had a wacky lockup. I was playing with the Karaoke plugin and using an external monitor. I went to load autoplay and start autplay and then I disabled the plugin and went right to the slideshow plugin, enabled it and then chose the sonique plug in and went to enable that one (by hitting activate)
CDJ locked up everything on the screen, the external monitor went black and nothing was responding (not even my DAC-2) The only thing that was accurate was the waveform on the screen and the music kept playing, no stutters, just automixing two songs back and forth.
no crashguard as I had to CTRL+ALT+DELETE to get out.
Any ideas?
geposted Fri 10 Jul 09 @ 11:08 am
I would say it's the sonique plugin.
I think I am going to take a break from using the plugins for a while. At least till I isolate the problem. I have 2 weddings this week so we will see how it goes. Thanks djcel
