I'm trying to set up my Audio 8 sound card for time code. I can't get it to work. I have the out of my CDJ's going to the in on the card, the out's of the card to the mixer. I'm get nothing in VDJ. Using the beta version hoping to get time code working. Any help would be appreciated.
geposted Fri 17 Jul 09 @ 3:24 pm
Hello Hitower..long time never heard from you;)
Do you use leopard osx or tiger osx? Have you tried both? Also If i remember correctly you do have the rmx too right? Can you tried that too. The older mk2 work good with the beta.
Also let's continue all regarding about timescode with the beta at the thread provided below for better communication and keep it at one place.
http://www.virtualdj.com/forums/109967/MAC_Version_Technical_Support/__Beta_6__Time_Code___.html
Kind regards;)
Kind regards;)
geposted Fri 17 Jul 09 @ 3:54 pm
