Forum: Old versions
Topic: NEED SOUND CARD ADVISE & RECOMMENDATION
Tried to get some info on a different thread but believe the thread is not being looked at any more so I started this one .
I was about to go shopping for a sound card Maya 44 then was advised that the M-Audio Conectiv is better. Since then several others are possible options. So could you please assist me in making the best choice for my set up (VDJ 6.0.1 to Pioneer DJM 800 & CDJ 1000 MK3's)?
-M-Audio Conectiv?
-Maya 44?
-Vestax VAI-80 (aka Little Tank)?
-other choices?
Thank you!
geposted Fri 17 Jul 09 @ 11:07 pm
geposted Sun 19 Jul 09 @ 2:50 am
The M-Audio Connectiv is a very good sound card
geposted Sun 19 Jul 09 @ 8:38 pm
ewitlesPRO InfinityMember since 2006
I have a 192L Waveterminal from ESI.
It seems to 'growl' when running ASIO and tempo change. WDM not much better. VERY fast system configuration.
I like the 8 ch output feature.
Will try my Gigaport HD and see how that works.
geposted Sun 19 Jul 09 @ 9:22 pm
+1
Syberman
geposted Sun 19 Jul 09 @ 10:11 pm
Thanks to all!! Shopping time.
geposted Sun 19 Jul 09 @ 10:16 pm
