Forum: Old versions
Topic: My Uploaded Mapper in Tools Disapeared?
I uploaded my zero4 mapper and a few days later i added a text file for the mapped buttons. after i uploaded the text file it was no longer up for download?
geposted Mon 20 Jul 09 @ 1:31 pm
no mods can answer this one?
geposted Wed 22 Jul 09 @ 6:46 am
when ever you make a change to your upload, add something, or remove it. The package will need to be approved again =)
Hopefully someone will approve it for you again.
geposted Wed 22 Jul 09 @ 6:47 am
ciocePRO InfinityMember since 2004
geposted Wed 22 Jul 09 @ 7:01 am
i have it mapped to VDJ6 but when i saved it into the folder it saves as simple midi device. how do i save it as KORG ZERO4 MAPPER its mapped exactly the same as i did for CUE so the text file should be the same.
geposted Wed 22 Jul 09 @ 7:49 am
spool32PRO InfinityMember since 2007
Theres nothing in that Zero 4 midi mapper download but a RTF file. Does anyone have anything that works? Honestly, all i really want to do is use the crossfader connected to VDJ
geposted Thu 30 Jul 09 @ 5:39 pm
