Topic: Songs in 7/8 time
If a song is in 7/8 time, is it possible to adjust the cgb's (?) to reflect this? As far as I can see it assumes that everything has 4 beats to a bar. Thanks.
geposted Fri 08 Apr 05 @ 12:53 pm
No you cant seperate the beat grid 4/4.......cbg squares move by group of 4
Regards
Andre
This is where creative use of cue points comes in. :)
what song is 7/8 ???
as far as theory goes, "all" normal songs are 4 by 4 beats
even break beats (hence the name, you "remove" one beat, that you can not hear, but you can still "feel" it there.... )
the cbg's will indicate where the "missing" beat is :)
this goes for hiphop, some r'nb, drum & bass, break beats and more
beatmixing ballads?...never thought to ask. Good point.
I can't remember the title but I have one 7/8 song too.
Dj In Norway : 7/8 songs are done by cutting (and not silencing) the last beat of a "normal" 8/8 measure, on each measure. This way it creates a great effect when used the right way.
VJD cannot handle this kind of rhythm, as it can't handle 3/3 rhythms...
Maybe an option could be added, like cue capability, to set manually song by song what rhythm the CBG should show...
FRUiT94
hmm.. ok :) I rest my case... hehe..
I said "all normal song"
there sure are genres, and songs that are not "normal" :) Meaning they dont follow the standard measure pattern, and VDJ are not made for those (cgb's)
my guess was simply that he HAD a 8/8 measure song, where one beat was silenced. And that he missed that point... but maybe not :)
If ever I can retrieve the song, I'll send it to you, my friend. Will not forget.
BEST Regards Norway!
FRUiT94
"Jocko Homo" by Devo is probably the most famous song in 7/8 time. I was hoping somewhere down the line, VDJ would have a way to account for odd signatures, even if it had to be done manually. I have a lot of waltzes, for instance, and the CBG is inconsistent as a result.
Is the fact that CBG is incorrect for 7/8 songs and Waltzes really causing a problem? Are people beatmixing these songs? And if they are, then with what? Other 7/8 songs? Other Waltzes? The relevance of this entire thread has me wondering what I'm even doing here. I think I better get back to work.
loooooool ;) I kinda felt the same way ;)
and your point is good.... BEATMIX is all about 4/4 beats measures...
I cant see the point with cbg's for "odd music"
But then again, I might be wrong
MAybe with waltz ...
