Forum: Old versions
Topic: FYI 10.5.8 out now.
sbangsPRO InfinityMember since 2004
Now available in software update:
"- Issue with CoreAudio and network MIDI drivers fixed"
Could be positive for people having problems.
- Resolved issue with changelogs and iDisk syncing
- Issue with CalDAV and meeting mismatches fixed
- Fixed memory leak issue with CoreData Framework
- Issue with iCal Synchronization and time syncing resolved
- Resolved issue with Image RAW and CEmbeddedTIFFThumbnail
- Fixed issue with SearchKit and Safari history searches
- Issue with AFP Server and TimeMachine syncing fixed
- Issue with HICocoaView and parent window positioning resolved
- HICocoaView Shift-Tab focus issue in NSForm views fixed
- Issue with simultaneous logins and LoginWindow resolved
- Resolved drawing performance issue with multiple HICocoaViews in a
single Carbon window
- Fixed issue where Startup Items on Network Home Folder were not
being executed in certain situations
- Issue with DictionaryTrainer and Japanese Language Analysis resolved
- Issue with LoginWindow UI and wireless logins fixed
- Issue with messages sent to deallocated NSTreeControllerTreeNode in
CD/bindings app fixed
- Fixed issue with SpotlightIndex and index rebuilding
- Formatting issue with USB MSC fixed
- Issue with NFS indexing and File Systems resolved
- Fixed issue where system may not sleep second time in certain
situations
- Resolved issue with Spotlight and MDItemCopyAttribute
- Fixed issue with DHCP Client and 802.1X integration
- Fixed authentication issue with CFNetwork HTTPAuthentication and ISA
2006 proxy servers
- Resolved issue with Sync Services Preferences Sync and automatic
syncing
- Fixed problem where iCal sync may fail when moving events to
different calendars
- Issue with DisplayPort->DVI/VGA adapters resolved
- Problem with Garbage Collection and NSImage fixed
This update should be fine but test it at home first.
We are currently testing the update with our products and will report back very soon.
geposted Wed 05 Aug 09 @ 4:58 pm
DJ CyderPRO InfinityModeratorMember since 2003
Early testing here in the VDJ labs, no major issues and some how safari seems quicker...
geposted Wed 05 Aug 09 @ 11:16 pm
dydy1PRO InfinityMember since 2006
Did It resolve some of the display problems we had with some of the Denon players and Mac update 10.5.7?
geposted Wed 05 Aug 09 @ 11:40 pm
I have another Hardrives with OSX installed on it with 10.5.7. I updated that hardrives with the new update OSX 10.5.8.
The results are as follow: The new mac update did not resolve the display problem I have with the Denon DN-S1200s, Virtual DJ V6 Mac latency seems to be even better. The cue button reacts more even more precise, The buttons on the Dn-S1200s react spectacularly well, It Is hard to explain but the sounds seem to be tighter but a bit too bright with reduced lows. Now I have no clue why The sound changed, could it be that Denon on their side needs new firmware for the DN-S1200s? could It be on Virtual DJ side because the V6 Mac Is still beta with some bugs? or could It be on Mac side just waiting to release the Snow Leopard? I don' t have a clue people.
geposted Thu 06 Aug 09 @ 4:52 pm
