recently bought virtual dj 5. working great but i can only speed up my tracks when i would like the pitch to be higher. i used to own atomixmp3 and it gave u the option to disable time stretch. can i do this with my new software?
thanx davie.
thanx davie.
geposted Sat 08 Aug 09 @ 5:08 pm
Hi there, welcome..
Do remember to register your serial and get the updates and the goodies;)
Click on the keypad icon (Keylock) on top of the pitch slider.
Regards;)
Regards;)
geposted Sat 08 Aug 09 @ 5:28 pm
i no u can press the pitch + button but i want to be able 2 mix aswell. as soon as u take the mouse of the button it goes back 2 normal ??
geposted Sun 09 Aug 09 @ 5:37 am
Click on the PADLOCK icon labelled KEYLOCK just below the -/+ buttons to turn keylock on/off (If you want the pitch of the song to change when you adjust pitch with slider, you want it off.)
Also, we would recommend you upgrade to the latest v6 version. It has a much better default skin and is a free update for users who have purchased VirtualDJ Pro.
To upgrade, first register your serial number http://www.virtualdj.com/users/edit.html and then go to the Download Center to download the upgrade: http://www.virtualdj.com/download/updates.html
geposted Sun 09 Aug 09 @ 3:34 pm
how do i get the pitch to stay up through my full set though? when i take the mouse of it, it just slows back down to the normal speed??
geposted Wed 12 Aug 09 @ 2:51 pm
