Forum: Old versions
Topic: HARD DRIVE!!!
MTOWNPPRO InfinityMember since 2008
JUST INSTALLED A NEW HARD DRIVE & IT'S NOT BEING RECONIZED IN THE BROWSER.
geposted Mon 10 Aug 09 @ 1:04 am
Have you enabled "Volumes" in the "Browser" section of the config menu?
geposted Mon 10 Aug 09 @ 6:43 am
DONT SEE A TAB FOR ENABLE BROWSER IN THE CONFIG SECTION.
geposted Mon 10 Aug 09 @ 8:40 am
That's because there is no "ENABLE BROWSER". Go to the config menu, click on "Browser", then click the box next to "Show Volumes". Then in the browser section of the VDJ skin you'll see an icon titled "Volumes", click on that and you will see your external hard drive. And for future reference, using all caps comes across like you're yelling.
geposted Mon 10 Aug 09 @ 4:15 pm
i see show volumes but its checked still not showing up plus its my internal hard drive i just upgraded it plus my virtual folders not saving. im not yellin.
geposted Mon 10 Aug 09 @ 8:29 pm
