Does anybody know how to set up this? I'm trying to use my headphones to prelisten a song. I don't want to use a sound card, but if i need to can anybody tell me the best and compact soundcard i can use. I'm trying to put together a compact and mobile set up.
geposted Tue 12 Apr 05 @ 4:06 pm
Use a graphics card then, or printer :D
Seriously, you mean "Prelistening songs with 1 sound card"? You'll have to use a Y split cable, which makes two mono outputs from one stereo. Thus you can connect one mono output to speakers/amplifyer and the secend one to your headphones. In VDJ, select the second (Stereo splitter) option under Sound Cards settings.
Regards.
Regards.
geposted Tue 12 Apr 05 @ 4:34 pm
graphic card.. looool =)
yes i was using Y split cable... but if you want to mix songs for real, buy another sound card. with only one you won't be able to use some effects and songs won't be playing with original sound.
Dj Nikki
Dj Nikki
geposted Tue 12 Apr 05 @ 5:19 pm
the soundblaster mp3+ usb card is VERY SMALL and handy
so is the cardbus indigo dj or what the name was again, if its a laptop pc. It's just a card in the slot :)
geposted Tue 12 Apr 05 @ 6:32 pm
If i am to use two sound cards, What are the recomended ones and how would i set them up?
geposted Wed 13 Apr 05 @ 5:00 pm
you don't need an expensive sound card. just buy one (internal or external) and plug into your computer. all settings are in VDJ where you see menu "sound cards". there you have to set 4th picture from the top. and then select to which one are connected headphones and to which one your speakers.
Dj Nikki
Dj Nikki
geposted Wed 13 Apr 05 @ 5:15 pm
I tried this with an M-Audio external And could not make it work. Could i have done something wrong?
geposted Fri 15 Apr 05 @ 5:26 am
We cannot help, if you don't actually give us some info on what you 'tried'...
Hardware obviously isn't the issue here, because it works with any sound card connected and working on your computer.
1) Is your sondcard connected and working?
2) Are your cables plugged correctly?
3) Did you select the right option in Sound Setup menu?
4) Are you using VDJ with external mixer?
It's very simple:
1st, you need 2 outputs:
1 soundcard with 1 stereo output (so you split it into two mono...) or,
2 soundcards with two stereo outputs or,
1 soundcard with 2 (or more) stereo outputs.
The cable setup goes like this:
1 cable goes to your speakers, 1 to your headphones or,
if you answerd 'yes' under 4): 1 cable to 1 mixer input, other cable to the second input in mixer, while master output (from mixer) goes to the speakers.
The setup in VDJ options depends on how many cards you use and how they are setup. I believe that pictures cannot possibly ilustrate it better than they do. :)
Still having problems?
Regards.
It's very simple:
Regards.
geposted Fri 15 Apr 05 @ 5:39 pm
