Forum: Old versions
Topic: Not Java Compatable???
sbangsPRO InfinityMember since 2004
Where are you trying to buy the samples?
You can load samples on the sampler tab, use the load button on each slot.
Regarding sound FX they should be copied into Documents / VDJ / Plugins / Sound Effects
geposted Sun 16 Aug 09 @ 8:44 am
teck83PRO InfinityMember since 2009
reguarding the samples, i was trying to download them here on virtual DJ via the download tab >plugins > samples....
thanx for the info about the sound FX!
geposted Tue 18 Aug 09 @ 7:27 pm
