Forum: Old versions
Topic: VirtualDJ 6 & Denon DN-HS5500 - Page: 2
Hi Cstoll,
one deck is on layer 1 and the other deck is on layer 2. I've also reset the players to factory default settings like you suggested.
geposted Thu 05 Nov 09 @ 8:51 pm
Does anyone know if the platter issues on the Denon DN-HS5500's have been fixed on the new version of VirtualDJ 6.0.3 ????
geposted Tue 10 Nov 09 @ 11:30 am
cstollPRO InfinityMember since 2004
John ... download and install 6.0.3 ... there were several performance issues address in this version ... (change log)
geposted Tue 10 Nov 09 @ 5:45 pm
I understand, but I didn't see any specific fixes towards the 5500 platters that's why I was asking.
geposted Tue 10 Nov 09 @ 8:17 pm
The issues with the 5500, I don't believe is specific to the unit ... it was performance issues of the software .. so that's why you don't see any specific 5500 statements listed.
fixed - lol
geposted Tue 10 Nov 09 @ 8:24 pm
Still listening. LOL
geposted Wed 11 Nov 09 @ 7:08 pm
So ... any luck ... are things better ?
geposted Wed 11 Nov 09 @ 7:25 pm
Didn't get a chance to try yet. I'll deffinately try it out this weekend. I'll keep you posted. Thanks for getting back to me.
geposted Thu 12 Nov 09 @ 9:26 am
Tried 6.0.3 last night and I'm still having the cue drifting problem with the moving platters on the 5500's.
geposted Fri 13 Nov 09 @ 8:52 am
John,
I went back through the posts and I am not sure what more I can suggest ... the Jog Sensitivity options should make a difference on how the track control relates to the velocity of movement from the controller. Maybe try changing the latency of the unit to the 10ms setting and see if that help ? But, I am running out of options ... :(
geposted Fri 13 Nov 09 @ 9:00 am
I'll try that. Thanks for all your help and support. Even though I have this issue you guys still rock and VirtualDJ is still the best DJ software in my opinion.
geposted Fri 13 Nov 09 @ 3:46 pm
John ... not sure if this guy is 'scratching' but here is a comment from another thread ... might try sending him a PM and see if you guys could compare notes ...
From - http://www.virtualdj.com/forums/115215/Hardware_Technical_Support/DENON_Hardware_Products_(Setup__Solutions__Fixes__Issues__etc_).html
obrab wrote :
i found the problem with the denon loosing signal had to do with the power setting on your usb root hubs in the device manager. If you turn off the power saving option in the usb root hub properties you should be good to go. I used win7 with 2 5500 friday for 9 hours straight with no issues.
geposted Mon 16 Nov 09 @ 8:09 am
I have a denon 5500 and I tried using VV with it in midi mode. I agree there seem to be no effect when adjusting the scratch sensitivity in 6.0.3. What I am trying to do, is convert all my files to mp3 since I use mostly ogg. The denon's are made for cds and mp3s If you are willing to part with cuepoints, and VV database then, external mass media device is the way to go. I guess we were better off with cds. Or you might just have a get a keyboard usb hub, and search the Db in Denon music manager.
Issues.
1. Scratch mode needs to improve. Drastically
2. Easy to access virtualDj effect not so easy on denon 5500, easier on numark Dmc2
3.There should be a autoloop feature.
4. The denon itself should be taught through programming how to read the database so where you make a cue point it will always jump back to that point. (when scratching). Instead of slipping. The only way this feat works okay with midi when scratching is taping the cue (1,2,3) when scratching. It returns the scratch to the point where you wanna catch the beat.
5. The echo suchs. Can we have echo like the one native to the denon 5500, when you stop the cue it echo's out.
All the controllers that use midi are not up to par with using Cds. I am happy that the techology is available, it makes it easy for us djs to get around with just a harddrive. But when other dj play thier cds the sound more professional because cd based platform tabletops and rack mounts are more stable than software controllers. And don't get me started on controll cds both from VV and Serato, worse peace of s*&*
geposted Mon 23 Nov 09 @ 10:18 am
obrabPRO InfinityMember since 2009
just wanted to bump, as you both know I have the same issue
geposted Tue 08 Dec 09 @ 9:09 am
I can not get the platter to spin at all, on either layer??????? what am i doing wrong? ASIO V1.01 for Vista 64. SYS 1400 on the 5500...factory defaulted the unit except for the Jog Trns setting to 10ms as per another post for vista. everything else seems to be working fine.....just No Platter movement at all on either layer???????????? does anyone have 5500's set up with Virtual dj 6.06 that works complete with moving and functioning Platter on a PC with Vista????????? If so what are your settings?
geposted Tue 29 Dec 09 @ 6:21 pm
geposted Tue 05 Jan 10 @ 11:51 am
Just tried the 5500's with the new firmware update (SYS1400) and they are reacting the same as far as que slippage when scratching. This leads me to believe that Silvio is right as far as the problem beying on the software side.
geposted Tue 05 Jan 10 @ 8:52 pm
Jason KPRO InfinityMember since 2007
Bump
I've tried everything i can through the forums, and I still have the same prob.
Ni audio 8 sound card with two dn-hs5500 (midi only)
geposted Sat 30 Jan 10 @ 5:09 pm
the thing is that you are not using the timecodes....i have a pair of cdj-400, which use the usb. it mixes great but the only problem of using usb directly and no timecodes is that your scratches will be off....trust me...i know what im saying...if you would get the serato sl1 box and use it as timecode...it will work like magic!!!!!!!!!
geposted Thu 04 Feb 10 @ 10:44 am
Does anyone know if the new update (6.0.7) fix the platter issues we've been having with the Denon DN-HS5500's?
geposted Mon 08 Mar 10 @ 11:03 am
82%
