Forum: Old versions
Topic: anyone using one timecode?
i cant set it up right iselect one time code external mixer and sl1 sound card and it wont work any ideas?
geposted Sun 30 Aug 09 @ 2:41 am
sischoPRO InfinityMember since 2005
Try to post your settings and you will help us to understand what the problem is.
geposted Sun 30 Aug 09 @ 5:30 am
Yeah, tell us what you have and how you set it up. I have run 1 timecode for years until I broke down and bought my 2nd deck.
geposted Sun 30 Aug 09 @ 10:52 am
i dont know how to show u guys my settings can you post yours?
geposted Sun 30 Aug 09 @ 11:01 am
cstollPRO InfinityMember since 2004
Just go through each of the Sound card, Performance, and Timecode config areas and write here what settings you are using ...
geposted Sun 30 Aug 09 @ 11:14 am
i dont get a time code signal
but if i use two timecodes i get a signal
problem is that one turntable broke
inputs single timecode
outputs external mixer
soundcard sl1 box
geposted Sun 30 Aug 09 @ 11:38 am
Ok, that is the sound card tab ... what about the other 2 I listed ?
geposted Sun 30 Aug 09 @ 11:53 am
latency 512
safe mode checked
overclocked checked
lowpass filter
filter taps 11
scratch
qualty checked
enhanced alogram checked
filter size 11
master tempo fast
i get no signal with one time code but they work in two timecode setting evrything is normal if i use two timecodes
geposted Sun 30 Aug 09 @ 12:12 pm
Are you sure your table is plugged into Side A (or whatever it may be called) on your sound card? I had that happen to me once. I had a single timecode, but had it plugged into Deck B of the soundcard.
geposted Sun 30 Aug 09 @ 12:52 pm
i will try that thanks i will let you know
geposted Sun 30 Aug 09 @ 6:09 pm
sphis
big thanks that worked
geposted Sun 30 Aug 09 @ 8:43 pm
