Topic: Virtual Vinyl 6.0.2
First off i want say thanks for the version 6.0.2. Numark has final released "THERE VERSION" it so far im impressed.
Few questions...
Is it ok to just install OVER my 5.2.1 version? without compromising? I've also noticed by doing this....Allot of my settings stayed the same so i didn't have to tweak much when installed. I'm still testing but so far so good!
Thanks,
geposted Tue 01 Sep 09 @ 8:58 pm
Yes, I installed Cue 6.0.2 right over my old Cue 5.2.1 and nothing changed as far as cue points, settings, databases on each drive, etc. It's all great so far.
DJ RuDe
Does anyone know if there will be a CUE LE 6.0.2?
Good question.
DJ RuDe
There is a difference in the version that reading the vob file is new though vitual vinyl 6.0.2 and virtual DJ pro6.0.2 are used.
A part of vob cannot be read. It is a similar trouble to virtual DJ pro 6.0.1.
It is not canceled in Virtual Vinyl 6.0.2 though it is canceled in virtual DJ 6.0.2.
It expects it of the next version.
virtual vinyl locks up from time to time when i want to select a different mp3 and in the middle of playing a song, it will freeze and the sound will cut off. does anyone else experience this???
estou com um problema, instalei a versão 6.0.2 mas está aparecendo um erro 24 alguem pode me ajudar?
obrigado
obrigado
Entre em contato com o Fórum Espanhol.
Aqui, infelizmente, muito poucos usuários falam Português.
Muito obrigado
Haui
[Google translater ;-)]
