Forum: Music discussion
Topic: How do I record my own voice effects on virtual dj? - Page: 1
Im a dj and im unsure about this procedure. If I want to shout out "WOW" on my dynamic mike, and record it as a fancy sound effect how would I do so?
geposted Mon 07 Sep 09 @ 12:25 pm
I'd also like to know if it is possible. Thanks
I do my sound effects and DJ drops through my Pioneer DJM-800 mixer which has effects that allow me to make some cool drops. I record them with either my Yamaha Pocketrac 2G or I do them through Serato with my SL3's record feature. I don't use VDJ to record because it can't send and return so I can record my mixer's effects through VDJ. It's best to do your drops with an external recorder.
DJ RuDe
For jingles (and remixing as well) I think ACID is an easy and useful program.
You can download a free version and try:
http://www.acidplanet.com/downloads/xpress/
Best with this is the "nondestructive editing". You can drag the sounds/loops around until you're satisfied, then just "render to new track".
For looped jingles there is BPM and good timestretch functions.
If you want to change something, just open the project, edit and render again. No cutting directly in the soundfiles makes it possible to edit without any quality loss.
Just a suggestion...
(and you can record directly into the program, for example your voice)
Thanks dj_ciceron
Will that Sofware be all that help full???
And how do i creat an artificial Jingle out of that like the TEXT and SAY software.
Willl luve to collect more skills form the Senior Djs Around this Hall,
Just 19 years .
Artificial Radio Or Dj name Jingle maker ! ! !
Maybe a little missunderstanding. I've never heard of artificial jingles "on the fly".
For me a jingle is a trademark, like a logo. So I want it to always sound the same, and be perfect mixed/produced.
Because of that I produce all jingles at home, and at a gig I just play them.
Only "artificial" I tried is AnalogX Sayit
http://www.analogx.com/contents/download/Audio/sayit/Freeware.htm
Technical you could with that render a wav-file, load it into VDJ and play it out.
U CAN MAKE A FILE ON A PROGRAM SUCH AS MIXCRAFT OR AUDACITY OR VARIOUS PROGRAMS AND SAVE YOUR VOICE FILE AND SIMPLY UPLOAD IT ONTO UR VIRTUAL DJ SAMPLES
dj_ciceron Thank you Very Very Very Much
This was what i was looking for exactly....
Thanks once again...
Thank you again and again.
Send me ur Email Address Ofline to cvv_deamon on yahoo so that i can email you and communicate with you frequently and privatly.
Thanks once again
Can Someone Help me
im trying to record a mix on virtual dj with my DMC2 but evrything that i do it records it..like when i cue the song,,or when i listen a part of the song on my headphones...
HOW CAN I RECORD A MIX WITHOUT GETTING ALL THIS????????
how do u get the text code..
How can i record my voice in virtual dj ??
Whats a easy way to earase the voice in a song usin virtual dj ??
Can any 1 help me?????
How can i record my voice like deee jayyy adi. Please any 1 can help me.
I'm just 18 years old and i want to be a wprld dj like my god of dj, Dj David
Guetta. And please send ur email adress at : *****@******
[Sorry, posting E-mail addresses and other contact details is not permitted for unlicensed users]
i need help with my software plz some1 help me xxx-xxx-xxxx
Post moderated - No Licence users cannot post contact information
Keith
I use Sony Soundforge & with all of its effecets it works great
djscorpio25 wrote :
Can Someone Help me
Just route a record loopback on to your PC and record it with an external software like audacity.
This link might help you...
http://de.virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
greetz
rob
Do you think he still hasn't worked it out after three years?
*LOL*....!!!
Think i should check my glasses...;-)
roBroY09 wrote :
djscorpio25 wrote :
Can Someone Help me
greetz
rob
thanks for the help
install audacity:
http://audacity.sourceforge.net/
then you can recorde your voice and play it on a deck.
if you want to put it on a sample : loop it and hit record.
Then you can rename it ....
DJmac221
How do i make my own jingles
Because i have search on the internet but couldn't get any answer,
so please if you know any software or webpage that can be used
Am a boy of 18yrs and i want to became a senior dj
So masters help to achieve my goals and aims
Please send to me through my email:*** removed ****
Moderator : Posting contact information is not permitted by No-Licensed Users as per our Forum rules
83%
