Hi friends,
I'm creating a skin (again) but I wonder why the play_pause button won't blink.
Even the play_button is blinkin'wrong. My cd-deck-playbutton is on when playing and blinking when in pause or stop.
With the action "play_button blink" it's inverted.
Am I doin something wrong or what?
best regards,
john
best regards,
john
geposted Mon 14 Sep 09 @ 3:36 pm
Still no answer here.
geposted Sat 10 Oct 09 @ 12:57 am
<button action="deck 1 play_button" rightclick=" deck 1 reverse while_pressed"> <------------ ok
geposted Sat 10 Oct 09 @ 3:50 pm
thanks TODO MIX,
But that is only play and not pause. And I want play_pause.
Best regards,
John
Best regards,
John
geposted Sat 10 Oct 09 @ 4:05 pm
in play and pause not possible!!
geposted Sat 10 Oct 09 @ 4:11 pm
djjb, try this:
in action, put: "deck 1 play_button"
and create a button in the skin with action="play_mode 'pioneer'"
Now try using the play button. Is this behavior you wanted?
geposted Sat 10 Oct 09 @ 6:19 pm
Hi JeremK,
I did what i think you mean. Temporary I replaced the play-button for deck 2 with the action "deck 1 play_mode 'pioneer'" and the play-button for deck 1 the action "deck 1 play_button". But the pioneer button don't work. It stays on "selected".
btw my skinversion is version="6".
Best regards,
John
Best regards,
John
geposted Sun 11 Oct 09 @ 1:07 am
Well, I have this now and it works for 90%. Only when you reload the skin, or startup vdj the button does nothing. After a click, or 2nd load (of a track) it works.
btw: the mask x="366" is pink and x="474" is black
I'm waiting for the skin-SDK....
Best regards,
John
<button action="deck 1 pause blink" rightclick=" deck 1 reverse while_pressed">
<pos x="50" y="665"></pos>
<up x="+0" y="+254"></up>
<size width="107" height="65"></size>
<selected x="+0" y="+0"></selected>
<mousemask x="366" y="1884"></mousemask>
<clipmask x="474" y="1884"></clipmask>
</button>
<button action="deck 1 play_pause" rightclick=" deck 1 reverse while_pressed">
<up x="+0" y="+0"></up>
<selected x="+0" y="+254"></selected>
<mousemask x="474" y="1884"></mousemask>
<clipmask x="366" y="1884"></clipmask>
</button>
Best regards,
John
geposted Sun 11 Oct 09 @ 1:33 am
try this
"deck 1 play activate ? deck 1 pause : deck 1 play_button"
it is ok for me
it is ok for me
geposted Mon 12 Oct 09 @ 2:20 pm
Thanks pasco123,
It's going to work, I know...
It works for so far, except when the button must be selected it isn't.(light out when play)
thanks for so far.
Best regards,
John
thanks for so far.
Best regards,
John
geposted Mon 12 Oct 09 @ 10:53 pm
Hmm,
all our trouble for nothing. it's so simple
It works
I thought I already tried. Maybe I reloaded the skin to fast after changing the XML.
thank you all
Best regards,
John
thank you all
Best regards,
John
geposted Mon 12 Oct 09 @ 11:15 pm
djjb wrote :
Hi friends,
john
john
yes sure, I believed that you wanted a button play_pause which flashes
whit this action
play_botton flashes and you can use play_pause to
geposted Tue 13 Oct 09 @ 4:36 pm
Hi again,
This is what I have done.
Best regards,
John
Best regards,
John
geposted Sun 18 Oct 09 @ 12:19 am
yes it`s possible!!
two buttons =
</button>
</button>
(disculpa mi ingles)
geposted Sun 18 Oct 09 @ 2:20 pm
Hi TODO,
Read 6 mess. earlier. I did the same.
geposted Sun 18 Oct 09 @ 2:37 pm
